Old 03-25-2017, 09:20 PM   #1
Who Dares, Wins
doc73's Avatar
Did you use the eternabond cleaner & primer for install?
So I am going to preemptively do all my roof seams with eternabond to take away any chance of ever having an issue while I own the trailer.
If you did the install did you use all the eternabond cleaner and primer products or did you just clean well (I'll probably use either mineral spirits or acetone sparingly) or did you just clean and go? Thanks.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 03-25-2017, 09:59 PM   #2
Canadian Member
I used acetone to clean the sealant and then used the aerosol can of Eternabond Primer before applying the tape. It adhered really well. If you have a rubber or TPO membrane on your roof be cautious not to get too much acetone in contact with the roof membrane.
When applying the tape I started at the rear of each roof penetration and overlapped the side pieces of tape over the rear piece and the front piece over the side pieces. I didn't use any Dicor on the edges of the Eternabond tape because it adhered so well.
Old 03-25-2017, 10:02 PM   #3
Jimsue's Avatar
Very trim and finished professional looking work. Did you remove the rain gutter to wrap the eternabond over the side edges of your rig?
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 03-25-2017, 10:07 PM   #4
Who Dares, Wins
doc73's Avatar
Thanks, I do not know what roof I actually have. No paperwork for it in my pile of useless user manuals! I've assumed a tpo or rubber and was aware of the risk of acetone or minerals spirits but it is still a good reminder for all.
I am leaving my gutters in place and going to lap it over the screws along the top edge to seal them as well.
2015 Chevy HD D-Max
Old 03-25-2017, 11:30 PM   #5
Jimsue's Avatar
Thanks. Please keep us posted. Looked like the OP completed the eterna bond seal along the sides already.... wonder how he did it.
2013 Sabre BKOK 31
Old 03-25-2017, 11:50 PM   #6
crunchman12001's Avatar
Following
2015 F-250 FX4
Old 03-26-2017, 12:00 AM   #7
Professional Curmudgeon
wrvond's Avatar
I've been using Eternabond tape for years. I've never used anything more caustic than dish soap and a scrub brush to prep the roof. Never had a leak, either.
This season I'll be re-bedding all the windows on my fiver. Not sure, but I think Eternabond sells a double sided tape. If so, that's what I'll be using.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 03-26-2017, 12:43 PM   #8
I resealed the entire edges of the roof on my motorhome with Eternabond, prior to making a decision several years later to replace the entire roof. However, the Eternabond worked perfectly, as advertised. I would use Eternabond again on any dicor sealant seam to eliminate the annual maintenance.
The decision about cleaning is an easy one. Do you care if it never leaks again, or are you happy with a poor install? If you want the product to properly adhere, you must prep the surface. I used both acetone and the Eternabond product, in different areas. Both are excellent, but watch out for painted surfaces that you will not be covering. It will take paint off.
Charlie
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2019 Jeep Wrangler Rubicon Unlimited
CharlieS3 is offline   Reply With Quote
Old 03-26-2017, 12:48 PM   #9
rsdata's Avatar
I used mineral spirits to take off any heavy duty crud (tree sap) then a rub down with drug store alcohol and allow to dry for a few minutes before applying the tape.
I did a write up summer of 2015 where I taped all of my roof seams... working well to date.
http://www.forestriverforums.com/for...nce-90060.html
2014 Shamrock 183
Old 03-26-2017, 12:57 PM   #10
I washed the roof and then cleaned the areas where I was applying eternabond with mineral spirits. I did the front and rear caps and around the skylight and tv antennae. Planning on doing the seams on the slides this year. So far so good. No leaks.
Fred
2013 Columbus 320RS
2016 F250 Lariat 4X4 Short Bed
2015 Nights Camped 72
2016 42
2017 15 so far
Fred and Christine is offline   Reply With Quote
Old 03-26-2017, 01:06 PM   #11
Who Dares, Wins
doc73's Avatar
Thank you all very much for your advice.
2015 Chevy HD D-Max
Old 03-26-2017, 06:18 PM   #12
Dakota EV's Avatar
I did the roof on my Sierra two years ago and everything is still ok. I did use the eternabond cleaner and primer on my camper after I washed the complete roof.
Freddie & Linda
2015 FR Sierra 330RLS & 2003 Dodge 2500 4X4 Diesel
TMPS for Camper & TV
Dakota EV is offline   Reply With Quote
Old 03-27-2017, 12:35 PM   #13
I called the roof manufacturer. They recommended denatured alcohol before applying Eternabond.
jgriffin7 is offline   Reply With Quote
Old 03-27-2017, 12:43 PM   #14
onetonford's Avatar
When I repaired my dinette skylite I used acetone their cleaner and primer. But I also used some white gas to remove the old eterna bond tape residue it works great but be careful it could cause problems with the rubber roof...
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 03-27-2017, 12:46 PM   #15
Herk7769's Avatar
I used the primer (acetone spray) followed by the tape; rolled down with a wall paper roller.
Name:	913th 3rd Annual Picnic and Camper photos 036.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 03-27-2017, 07:54 PM   #16
Who Dares, Wins
doc73's Avatar
Thank you, I ordered myself two rolls and a steel roller.
2015 Chevy HD D-Max
Old 03-27-2017, 08:40 PM   #17
dieselbobcat's Avatar
Doc- we are on the same wavelength... ordered some 6" tape and wanted to do the same at end of season, but didn't get a chance to complete before the cover went on... hopefully uncovering this weekend and getting it done... really don't like the front seam on my TT - looks like dicore cow pie.
2021 Cedar Creek 37MBH
2020 F350 Powerstroke Super Duty Lariat Crew Cab
Northern NJ - God Bless America!
dieselbobcat is online now   Reply With Quote
Old 03-27-2017, 08:48 PM   #18
Who Dares, Wins
doc73's Avatar
Yeah, they did ok on ours. I did see a few little pimples starting the the front seam. Sides and rear look goods but I just want to do it so it will be done for my ownership of this TT!
2015 Chevy HD D-Max
Old 03-27-2017, 08:48 PM   #19
Who Dares, Wins
doc73's Avatar
Is that all it is? Acetone in a spray bottle for $39 a can?
2015 Chevy HD D-Max
Old 03-27-2017, 08:56 PM   #20
Doc- you ever find a spot for ringing rocks?
eternabond
