Old 04-25-2017, 09:40 PM   #1
kittlecat's Avatar
Does anyone know about this product?
I am interested in using something like Eternabond on the roof of my TT so I won't have to worry about constantly checking the roof/seams anymore. I saw a product at Menards called Protecto Form Flash 1 Conformable Flashing Tape that appears to be used for roofing on a sticks/bricks home.
Does anyone know if this product can be used on the roof of an RV to seal seams? I have not purchased any but am curious to know what others think.
https://www.menards.com/main/buildin...52044155232068
Kittlecat
"Integrity simply means not violating one's own identity." Erich Fromm
"You have to understand who you are to know who you are not." Anonymous
"Know yourself, know your world. Change it." Anonymous
kittlecat is offline   Reply With Quote
Old 04-25-2017, 09:46 PM   #2
jtstromsburg's Avatar
I don't think that's as similar to eternabond as some tapes. It appears to be for vertical surfaces.
Maybe something more like this? https://www.menards.com/main/home-de...15589552874197
I have a different brand than eternabond, but don't recall the brand name. If you know a flat roof contractor In your area, they may be able to supply you with some, possibly even some left overs at a better cost.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-26-2017, 01:57 PM   #3
Why not use Eternabond?
ray98 is offline   Reply With Quote
Old 04-27-2017, 05:30 PM   #4
kittlecat's Avatar
I know Eternabond is really good, but the cost is significant for me at this point in my life.
Kittlecat
Old 04-27-2017, 05:32 PM   #5
kittlecat's Avatar
Thanks for the link! My nephew was a contractor so I will check with him and see if he or his business partner can give me any suggestions. I'd love to use Eternabond but it is rather pricey.
Kittlecat
Old 04-28-2017, 12:40 PM   #6
I've used Eternabond and I've used others. Eternabond wins. When the other stuff fails it still does one thing very well. It gives you something else to curse at. Also price listed above is really close to same size roll of Eternabond on EBAY. Just search by width and length
newcowg is offline   Reply With Quote
Old 04-28-2017, 12:45 PM   #7
Bobaloo's Avatar
It says Rated 30 days UV protection. Don't try it, I wouldn't trust it.
2013 Rockwood 2504
2015 Silverado 1500 4x4 Z71 Double Cab
Diablo and Lew Custom tuned
Tony & Catnis, campin' kitties
Bobaloo is offline   Reply With Quote
Old 04-28-2017, 01:51 PM   #8
Eternabond tape is pretty inexpensive on eBay.
D-Man is offline   Reply With Quote
Old 04-28-2017, 01:57 PM   #9
Expensive is relative. Eternabond is cheap when compared to water damage repair. Like my DW states "once and done"
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-28-2017, 02:01 PM   #10
I have had very good experience with Gaco Roof Tape. You must overcoat it with Gaco Roof (Silicone Liquid), but both remain flexible. I have used it on my house and two RVs.
https://gaco.com/product-details/gacorooftape/
Anyone else use it?
-Richard
Richard W Eason is offline   Reply With Quote
Old 04-28-2017, 03:15 PM   #11
I used Apoc Incredible tape. Got it at ABC Supply (roofing supply house - locations all over the US). If your nephew is/was a contractor maybe he can finagle wholesale.
See this thread:
http://www.forestriverforums.com/for...le-119068.html
gastan is offline   Reply With Quote
Old 04-28-2017, 03:50 PM   #12
DouglasReid's Avatar
Anyone else use it?
-Richard
I used the Gaco Liquid Roof Tape. It does not need to be over coated with the roofing material according to the local dealer. I covered all my lap sealant with it.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 04-28-2017, 04:00 PM   #13
DouglasReid - I was describing the (non-liquid) Gaco Roof Tape (comes in rolls). I agree that the Liquid Roof tape does not require any further coating. See:
https://41z32e1503dj3gyqe3151089-wpe...Tape-GRT50.pdf
Old 04-28-2017, 04:11 PM   #14
I fully understand and was not criticizing, just offering another option. You could also use the tape and coat it with the Liquid Roof tape for additional protection on the seams. the price for a gallon of the Liquid Roof tape and the Silicone Flex sealant are pretty much the same at around $90.00 per gallon.
I even applied it over the couple of bubbles on my roof. I thought about cutting the roof and eliminating the bubble but could not bring myself to intentionally make a hole in the roof membrane. I just wanted to reinforce those areas I thought may be weak.
Old 04-28-2017, 05:27 PM   #15
It sounds like you are trying to do it as cheaply as possible no matter what it costs. Eternabond is a proven product for use on RV roofs - it works!! You can use something less expensive, but in the long run what you save in tape will be spent ++ fixing the damage that can occur.
veraken is offline   Reply With Quote
Old 04-28-2017, 05:45 PM   #16
just need to make sure that the other tape is rated for your type of roof- many stick homes uses petroleum based tapes - not good to use on tpo or edpm not sure which type roof you have
AlanZ is offline   Reply With Quote
Old 04-28-2017, 06:18 PM   #17
No worries there, the Doco products are certified for use on EPDM roofing material.
Old 04-28-2017, 07:03 PM   #18
Mrpsyko's Avatar
Dont use it
It is made with asphalt which is a petroleum byproduct which is bad for your EPM roof. Use Etherbond.
2017 Flagstaff Super Lite 26RBWS/2014 F150 XLT SCREW 5.0 V-8
https://www.forestriverforums.com/at...pic35767_3.gif
Mrpsyko is offline   Reply With Quote
