Old 07-11-2011, 10:45 AM   #11
ken0042's Avatar
Silly question- but what was the temperature outside when you checked?
I bought my trailer late fall so the first chance I had to try the A/C was in the spring. The temperature outside was around 15C/60F; and I wasn't getting any cold air. The next time I tried it the temperature was closer to 25C/75F and it worked just fine.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 07-11-2011, 05:28 PM   #12
I had the same problem with my new TT. Worked fine at the walk through when i picked it up and didn't work after I brought it home. Turned out to be the yellow cooling call wire was loose on the thermostat terminal. May not be your problem but it might save you the trip to the stealership. Be sure to disable all power at the breaker first.
ikemeyer is offline   Reply With Quote
