04-27-2017, 08:54 AM
#21
All good suggestions. But I'll take the bold step and say maybe hide the keys and power tools from DW.
A little independence on how to arrange shelf in cupboards and such is one thing, but drilling holes in the side of my TT for television mounts?
Not going to happen.
RMc
04-27-2017, 09:12 AM
#22
RMc
This is EXACTLY what I was thinking!!!
04-27-2017, 09:36 AM
#23
in the side of "my TT". Now that's funny.
04-27-2017, 09:40 AM
#24
The house is hers. The TT is mine.
04-27-2017, 10:17 AM
#25
Sounds good as long as she isn't around to hear it .
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-27-2017, 12:10 PM
#26
One other suggestion would be to mount a holder for a small flag using the hole and display your patriotism!
04-27-2017, 12:13 PM
#27
Amen!.
We do tend to talk big when they're not around, don't we!
04-27-2017, 12:14 PM
#28
Properly seal hole. Then RTV (or similar) a yellow flat plastic reflector over boo boo. Use a red one for when she puts a hole abaft the beam.
04-27-2017, 12:16 PM
#29
Fiberglass repair kit from any auto parts store or walmart. Apply per instructions,sand it, mask it and spray a little dupli color. Your dealer should have the color so you can get a good match. Then wet sand and spray a bit of clear over it. Did it to the MH when it was new after a mishap with relying on the back up camera to much. You have to look very close to see I did it and I am not even a novice paint tech.
04-27-2017, 12:24 PM
#30
That's not a hole,........it's a tunnel !!
04-27-2017, 12:57 PM
#31
1/2 inch plastic plug they use on cars when they drill for undercoating. Cost pennies and seals tight. Get them at most any auto parts store. As far as an accessory, maybe you could add another outdoor speaker out there? Good luck.
04-27-2017, 12:59 PM
#32
Next time use a Zircon Stud Finder. Saves a lot of grief. RV walls are thin.
04-27-2017, 01:43 PM
#33
RetiredRVer
Use a stainless steel bolt with silicone thru the hole....long enough so she can continue mounting the TV mount!
Joe & Sandy
Mentor, Ohio
2017 Ram Laramie Longhorn Crew Cab 4X4 Cummins Diesel
2017 Coachman Chaparral 336TSIK Fifth Wheel
2018 AT 18 Alaska group
04-27-2017, 01:47 PM
#34
Originally Posted by Mr Havercamp
Buy a wall mount porch light to match the OEM one and after sealing the hole, stick the light over it with 3M molding tape. You'll be the only one who knows it doesn't work, unless you get creative and can get some wiring to it somehow, and If you ever trade it in it will drive the dealer bonkers trying to figure out why it wont work LOL.
Good solution but THINK!
The hole is going to a TV mount! How easy would it be to snake a wire through that hole and get some 110V power right at the source!?
Or a Security camera/scare light might be a good thing to do as well.
Still, like Mr. Havercamp sez, no one will know -- and if it is a security camera, how cool a mod will THAT be??
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
04-27-2017, 01:50 PM
#35
04-27-2017, 01:57 PM
#36
Originally Posted by Chrisplus4
Thanks for the suggestions and the great effort to make me laugh. Good to know that there are people with my kind of sense of humor. After sleeping on it, it's not the end of the world. I will get it sealed and get a decal that matches the others to cover it up. Still a little
upset, but not as bad as when my wife took the side of our motor home out at the gas pump! [emoji23][emoji23]. I got over that too!
Think I see a pattern here.....
2015 Freedom Express 246 RKS (Sold 2021)
2021 Grand Design Reflection 150 295RL
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2021: Still Not Enough
04-27-2017, 02:08 PM
#37
You can use this event to your advantage. Now your wife owes you a pay back. Use it the next time you screw up.
04-27-2017, 02:10 PM
#38
Put one of those peep sights that they use on motel doors.
04-27-2017, 02:57 PM
#39
Originally Posted by BamaBob
You are on to something! I like the 2nd one. That should be fine to travel with. I like that a lot.
04-28-2017, 12:51 AM
#40
If the exterior is whitee buy some Marine-Tex.Its epoxy two part filler for boats works great on trailer boo boos, can be sanded and painted,or not.
