Old 04-02-2016, 10:35 PM   #1
Easy install Vent fans??
Good evening all. I was wondering if there is a fan vent that is an easy swap out. The powered fans that I've seen, are ones that you have to remove the cover from the roof, install the new one, and reseal it with Dicor. Is there one that just installs from the bottom? I really don't want to remove it from the top, but it's not out of the question. Just wanted to know if there are any easier solutions. Thanks.
377FLIK
kasedian is offline   Reply With Quote
Old 04-02-2016, 10:37 PM   #2
The title was meant to read "Vent" fans.
377FLIK
Old 04-02-2016, 10:39 PM   #3
Wa11y757's Avatar
I believe the vortex fans are done from the inside. Look up rv vent fan upgrade kit. Hope it helps.
Wa11y757 is offline   Reply With Quote
Old 04-02-2016, 10:46 PM   #4
ov845's Avatar
I just upgraded our bedroom fan, the upgrade was done from the inside. When the weather is a little warmer I'll be installing a fan in the living room vent. That has to be done from the outside.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
Engine 5.7L Gear 3.92
Airlift 1000
2015 2809W Windjammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 04-03-2016, 07:17 AM   #5
World Wide Wanderer
wahoonc's Avatar
It will depend on the brand and type of vent you have. I know that Fantastic Vents can be upgraded from the inside no problems. The Vortex upgrade fan will fit "most" vents if they are the correct size.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 04-03-2016, 01:27 PM   #6
BooBoo23's Avatar
Get a Vortex II upgrade kit from Amazon. They have single speed or 3 speed with reverse. The 3 speed model is just under $60, a whole lot cheaper than CW, by about $50. I replaced the vent fan I had that didn't do anything with the kit. It took about a 1/2 hour to do it from the inside, maybe 3/4 hour if you don't read the instructions. I got the multispeed fan and it does a great job. Not as noisy and the old on also.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015 - 47
Camped 2016 - 58 done - 13 more planned so far
2017 - 14 nights reserved
BooBoo23 is offline   Reply With Quote
Old 04-03-2016, 04:25 PM   #7
Try this:
Amazon.com: RV Roof Vent Vortex II Ugrade Kit Multi-Speed Fan: Automotive
PenJoe is offline   Reply With Quote
fan
