Old 12-24-2018, 08:43 AM   #1
Eternabond as preventative Maintenance
Thanks to RSDATA who started this 2015 thread.
Roof preventive maintenance
The warranty period has recently passed on our rig. I am ready to apply eternabond to the roof perimeter. I had originally considered just the front and back seams but after some inspection on the sides last week, looks like it would be prudent to cover the sides. RSDATA has covered this application well in his posts.
I have a few questions for those of you that have done this;
-Preparation. Some have used mineral spirits followed up with IPA (Isopropyl alcohol), others have used acetone. Eternabond recommends eterna-clean or acetone in this instruction doc. I am just checking with you guys, did you use acetone or eterna-clean?
Sides of front cap: My rig is a darker color. I would like to run the eternabond tape down the vertical sides of the front cap...but it would look like crap due to the bright white tape. Have any of you done it on a darker trailer?
Sealant on tape edges: I have seen several posts where folks use dicor sealant around the tape edges. Lots of commentary about no need for this due to the tape sticking so well. Did you use sealant on any of the edges?
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is online now   Reply With Quote
Old 12-24-2018, 08:55 AM   #2
Chuck_S's Avatar
The four-inch wide Eternabond tape applied to the roof seams of my Roo 23SS in 2005 is still in excellent condition after 13 years as verified when I was on the roof putting the winter cover on earlier this month. No peeling or anything else. This trailer has always been covered or indoor stored at least 5 months a year in the winter but that's still a lot of time in he elements.
Preparation before taping included a ruthless cleaning of all surfaces with denatured alcohol. A couple quart cans are cheap at Lowes or Home Depot.
Sample of one (1) of course. YMMV.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 12-24-2018, 09:02 AM   #3
Flybob's Avatar
I used Eterna-Clean when I did my front and back seems. Worked well and easy to use.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-24-2018, 09:05 AM   #4
hack522's Avatar
I just applied to my 2009 23SS this fall. Applied to end seams along with around the vent, AC unit and all other roof extremities. I used their solvent cleaner before applying. I also had some denatured alcohol to insure a clean area before applying. No additional sealant was used.
Followed the instructions completely. Decided not to go to the sided even though the unit is white. Instead I'll reseal this spring with the correct caulk/sealant.
Good luck. Merry Christmas.
hack522 is offline   Reply With Quote
Old 12-24-2018, 09:22 AM   #5
rp53's Avatar
thinking of doing this as well do you remove the factory caulk or jus tape over it ??
2017 Micro Lite 21FBRS
2017 GMC Sierra double cab Z71
rp53 is offline   Reply With Quote
Old 12-24-2018, 09:49 AM   #6
hack522's Avatar
In my case, I went right over it. I viewed numerous videos on the way to apply. No need to remove the old sealant.
Old 12-24-2018, 10:00 AM   #7
rp53's Avatar
Thanks !
Old 12-24-2018, 12:56 PM   #8
Chuck_S's Avatar
Same same. Directly over existing caulk. There were big blobs of caulk over rivets or screws (or something) that I razored flat on one end and left the other end as built. Both ends are fine and unless you're 30' above the trailer the blob raised nubs are invisible.
-- Chuck
Old 12-24-2018, 01:09 PM   #9
I cleaned with soap, water, and scrub brush, let dry one day. Then cleaned with lacquer thinner as I worked an area. 4 inch strip on back, then cut into 2 inch strips for sides, then 4 inch across front. All tape rolled down with heavy metal roller. Applied over old sealer except for couple of Big blobs which I trimmed. No additional sealer needed.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 12-24-2018, 01:16 PM   #10
I just cleaned mine good with mineral spirits and applied right over sealant.
Decon Blue is offline   Reply With Quote
eternabond, maintenance, vent
