Old 10-21-2011, 10:44 AM   #11
Rugged Brown's Avatar
Originally Posted by RV Guy View Post
RB - you're definitely right about cleaning. That's always a concern for us, too.
Did you just do the perimeter of the roof like puckdad?
PTM
I did the front and rear seams, the vents, antennae, and plumbing pipes. I did not do the sides as the roof wraps around, nor did I do the AC.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-21-2011, 11:07 AM   #12
frankm's Avatar
Same here.
Originally Posted by lindy View Post
In this case an ounce of prevention is better then a ton of cure.
Agree 100%
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-21-2011, 11:38 AM   #13
Commercial Member
RB - Where were the areas that peeled?
RV Guy is offline   Reply With Quote
Old 10-21-2011, 11:43 AM   #14
The front seam. First noticed it when driving through heavy rain. This was the section I had most difficulty doing and the section that didn't get cleaned the best. In retrospect, I probably should have spent the most attention to this area, considering it was the area that likely got exposed to the elements the most.
Terry/Bernadette
Lily the Yorkie
Old 10-21-2011, 12:11 PM   #15
lindy's Avatar
All I did to the roof after applying the tape was wash it each spring and fall with DAWN dish soap. But like the instructions say it MUST be completely cleaned with acetone before application of tape. It took longer to clean then apply the tape. I taped both front and rear roof seams, along both side edges (incase of a branch scrape), and around skylights, vents, fridge vent, etc, basically everything on the roof except the AC.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-21-2011, 08:25 PM   #16
The only reason I did over the sides where the roof rolls over is that our previous 'new-to-us' trailer had major damage occur when water got inbehind the gutter (which also doubles as the method of securing the rolled over roof material), found the screws, travelled along the screws and once it made it to the roof sheeting it whicked itself up about 8-10" - what a mess!!
Glad I won't have to worry about that anymore
Mike
Me, DW, 3 sons (19, 16, 15) & RIP Joey the mutt
'11 Salem 26TBUD
'01 F350 RWD V10
puckdad is offline   Reply With Quote
Old 10-25-2011, 10:59 PM   #17
Eternabond, acetone, and primer?
Just ordered 2 rolls of Eternabond 50' x 4" for my SV-305. Do most of you agree that acetone cleaning and steel roller is the way to go, or should I also use the primer? The Di-chor lap sealant is still very sticky and pliable (TT one year old). I want to eliminate as much roof work as possible...flying doesn't bother me, but getting on the roof of my TT does.
Thanks.
Pilotdaddy1 is offline   Reply With Quote
Old 10-26-2011, 05:32 AM   #18
frankm's Avatar
Thanks.
Yes acetone or Eternabond own cleaner (which is 60% acetone) is what most people have used prior to the tape application. However please note that if you have an AlphaSystems rubber roof their maintenance instructions warn you against the use of acetone When I did our roof I tried to keep the acetone to just the area the tape makes contact with.
Frank & Rita M
Old 10-26-2011, 09:12 AM   #19
I used acetone and as I stated earlier, areas that I wasn't as diligent as I should be resulted in poor adherence. I did not use the roller either. I applied pressure with my fingers and hands. That worked fine where I cleaned it thoroughly with acetone.
Terry/Bernadette
Lily the Yorkie
Old 10-26-2011, 07:22 PM   #20
Thanks for the info. I will get this project underway as soon as my tape arrives.
eternabond
