Old 10-21-2011, 12:42 AM   #1
Eternabond complete....well, almost
Recently finished applying Eternabond tape to our '11 Salem 26TBUD.
Did both front and rear seams, fridge vent and after removing the vinyl cover strip that covers the screws, the entire length of the gutters.
Total time (over a few days) was about 7 hours, but I'm slow.
Just need to order another roll to finish the plumbing vents and antenna.
Cheers,
Mike
Me, DW, 3 sons (19, 16, 15) & RIP Joey the mutt
'11 Salem 26TBUD
'01 F350 RWD V10
puckdad is offline   Reply With Quote
Old 10-21-2011, 01:27 AM   #2
Location: Canandaigua,New York (The heart of the Finger Lakes)
Nice job ! NO LEAKS HERE !!
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
BigRed is offline   Reply With Quote
Old 10-21-2011, 04:43 AM   #3
EastlakeRoo's Avatar
This is good stuff. I did our 2010 this year as well. Hope to have years of leak free issues.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 10-21-2011, 05:50 AM   #4
Commercial Member
Interesting - it's easy to understand what you're trying to accomplish with this and it seems that the issue of "routine maintenance" to your seams basically disappears.
But (and I'm really wondering because I don't know) to what degree does this prevent leaks in these key areas over time?
I'd like to hear from anyone who has done this several years ago on a unit and what were their results. Again, not saying it won't work, I'm just curious.
PTM
RV Guy is offline   Reply With Quote
Old 10-21-2011, 07:24 AM   #5
lindy's Avatar
I did this to my ROO 23SS and the 5 years I had it, I had NO leaks. My new Ultra Lite 2604 will get the same treatment in the spring. In this case an ounce of prevention is better then a ton of cure.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-21-2011, 07:26 AM   #6
Commercial Member
lindy - given you did this to the roof, did you ever do any other maintenance in the areas where you applied the ETERNABOND?
Old 10-21-2011, 07:53 AM   #7
Rugged Brown's Avatar
I applied eternabond tape early summer based on the feedback from this forum. I got lazy toward the end and now those areas that I didn't thouroughy clean with Acetone is not adhering. If you are deligent and do a good job of cleaning before applying, this stuff will stick pretty good. I cannot comment on the long term effectiveness of it.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 10-21-2011, 07:59 AM   #8
Commercial Member
RB - you're definitely right about cleaning. That's always a concern for us, too.
Did you just do the perimeter of the roof like puckdad?
PTM
Old 10-21-2011, 08:49 AM   #9
sherdep's Avatar
wow - thats looks pretty clean in the way you laid out the stuff versus using the Dicor Lap Sealant.
wondering what's the diffrence in cost though - Dicor Self Leveling Lap Sealant tube is about $8 or $9 a tube and when I did my roof - I used 2 tubes.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-21-2011, 09:10 AM   #10
grhodes50's Avatar
Looks really good puckdad!
I have also had questions about how well eternabond holds up over time. I've read many post where people have applied it with great results intially, but lindy's post is the first one I have read where it's been 5 years since he applied eternabond.
When I asked my service manager about eternabond he told me he sees a lot of tt's where the eternabond is curling up at the edges after 3 years or more. I'm just guessing that whoever applied the eternabond didn't prepare the surface properly.
Old 10-21-2011, 10:44 AM   #11
PTM
I did the front and rear seams, the vents, antennae, and plumbing pipes. I did not do the sides as the roof wraps around, nor did I do the AC.
Terry/Bernadette
Lily the Yorkie
2019 FR Vibe 28RL
Old 10-21-2011, 11:07 AM   #12
frankm's Avatar
Same here.
Agree 100%
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-21-2011, 11:38 AM   #13
Commercial Member
RB - Where were the areas that peeled?
Old 10-21-2011, 11:43 AM   #14
The front seam. First noticed it when driving through heavy rain. This was the section I had most difficulty doing and the section that didn't get cleaned the best. In retrospect, I probably should have spent the most attention to this area, considering it was the area that likely got exposed to the elements the most.
Terry/Bernadette
Lily the Yorkie
2019 FR Vibe 28RL
Old 10-21-2011, 12:11 PM   #15
lindy's Avatar
All I did to the roof after applying the tape was wash it each spring and fall with DAWN dish soap. But like the instructions say it MUST be completely cleaned with acetone before application of tape. It took longer to clean then apply the tape. I taped both front and rear roof seams, along both side edges (incase of a branch scrape), and around skylights, vents, fridge vent, etc, basically everything on the roof except the AC.
F.R.O.G. member
Old 10-21-2011, 08:25 PM   #16
The only reason I did over the sides where the roof rolls over is that our previous 'new-to-us' trailer had major damage occur when water got inbehind the gutter (which also doubles as the method of securing the rolled over roof material), found the screws, travelled along the screws and once it made it to the roof sheeting it whicked itself up about 8-10" - what a mess!!
Glad I won't have to worry about that anymore
Mike
'11 Salem 26TBUD
'01 F350 RWD V10
Old 10-25-2011, 10:59 PM   #17
Eternabond, acetone, and primer?
Just ordered 2 rolls of Eternabond 50' x 4" for my SV-305. Do most of you agree that acetone cleaning and steel roller is the way to go, or should I also use the primer? The Di-chor lap sealant is still very sticky and pliable (TT one year old). I want to eliminate as much roof work as possible...flying doesn't bother me, but getting on the roof of my TT does.
Thanks.
Pilotdaddy1 is offline   Reply With Quote
Old 10-26-2011, 05:32 AM   #18
frankm's Avatar
Thanks.
Yes acetone or Eternabond own cleaner (which is 60% acetone) is what most people have used prior to the tape application. However please note that if you have an AlphaSystems rubber roof their maintenance instructions warn you against the use of acetone When I did our roof I tried to keep the acetone to just the area the tape makes contact with.
Frank & Rita M
Old 10-26-2011, 09:12 AM   #19
I used acetone and as I stated earlier, areas that I wasn't as diligent as I should be resulted in poor adherence. I did not use the roller either. I applied pressure with my fingers and hands. That worked fine where I cleaned it thoroughly with acetone.
Terry/Bernadette
Lily the Yorkie
2019 FR Vibe 28RL
Old 10-26-2011, 07:22 PM   #20
Thanks for the info. I will get this project underway as soon as my tape arrives.
eternabond
