Old 04-29-2019, 05:40 PM   #1
Eternabond or something else?
My slide out has square pieces of some kind of sealing tape in the upper corners of outer trim piece where it touches the bulb seals when the slide is shut. The front piece came off the second year I had the trailer and made a mess with the sticker sealer stuff on the back of the tape. It even tore my bulb seal because the bulb seal stuck to the glue stuff when I opened the slide. The dealer replaced the bulb seal and the square tape stuff. I just got back from a long trip to Florida and the tape was starting to bunch up again and expose the glue stuff underneath it. I'm including a picture of the tape to see if it is eternabond. Do you think flex tape would work better or be less of a mess when it does mess up? I just spent 30 minutes cleaning the glue residue off everything. That side if the slide closes a little tighter than the other side and I think when the slide closes and shifts a little it moves the tape. Worse when it is warm outside.
ID:	203185   Click image for larger version
ID:	203186   Click image for larger version
bigmurph is offline   Reply With Quote
Old 04-29-2019, 05:56 PM   #2
Iwannacamp's Avatar
Hmmmm. Maybe Chinese Eternabond. Get some real stuff. Follow directions and reinstall.
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 04-29-2019, 08:42 PM   #3
Do you think Forest River would have used something different? It happened twice already. Originally it was black but when the dealer replaced it they used white. Should it be strong enough to handle pressure and movement?
Old 04-29-2019, 09:07 PM   #4
If Eternabond isnít holding up, FlexTape wonít either.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 04-29-2019, 09:32 PM   #5
Iwannacamp's Avatar
Is it doing it on both sides? Slide may be out of adjustment.
2017 Puma 297RLSS
Old 04-29-2019, 10:04 PM   #6
Only on one side. The slide is a little tighter closing on the side that is messing up. I would hate to adjust the slide though since I don't have any issues opening or with leaking.
Old 04-30-2019, 01:15 PM   #7
What is the purpose of the tape? Is it holding the top and side pieces of trim together? I don't recall seeing that on the slide trim of my trailer. If it is needed to hold the trim pieces together how about replacing it with a layer of Bondo or epoxy?
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 04-30-2019, 04:07 PM   #8
Mine has similar tape, but it is black. I think the might have used it to hold the trim together when they installed it to the camper?
corocky1998 is offline   Reply With Quote
Old 04-30-2019, 06:31 PM   #9
Iwannacamp's Avatar
Omg. I looked for like the 5th time. That is the top under the topper...lord. I thought that was the bottom/side. Sorry.
I too see no reason for it.
2017 Puma 297RLSS
Old 04-30-2019, 06:47 PM   #10
I see no need for it, unless I'm missing something. What could it possibly do?
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
eternabond
