Old 09-03-2019, 04:35 PM   #1
Exterion compartment hinges problem.
During my trip to Canadian NWT and Yukon with some driving on unpaved roads I started having problem with hinges on outside compartments doors. The hinges get dust in them and after that I cannot close the door as it's forced out from it's normal location (plastic hinge gets deformed). Being on the road I was able to resolve this situation by cleaning the hinge with small diameter wire that I can insert in that hinge to blindly dig that dirt out of there. This process is very slow and because of that is not suitable. I could not remove any doors with such problem because I could not unscrew a screw that holds the end piece in that hinge. I assume that is steel screw in aluminum thread. Mostly this problem occurs in a vertical hinges and hinges that are lower, near the bottom. Had anybody has similar problem and possibly found a solution?
See pictures.
Thanks!
ID:	214152   Click image for larger version
ID:	214153   Click image for larger version
Severin & Ellen
1991 Westfalia Vanagon GL full camper
1997 Eurovan full camper
1984 Catalina 36 hull 268 (sailboat)
2017 Coachmen Freelander Micro 20CB
Ford Transit 350 HD cutaway chassis.
C36hull268 is offline   Reply With Quote
Old 09-05-2019, 09:07 AM   #2
Correction.
I was wrong - those hinges are aluminum, not plastic. However it does not change much. I was able to wash the dirt out of the hinges at home with a garden hose directing a stream of water in certain way in each hinge. But that's not an option if one is on the road in the middle of nowhere.
Severin & Ellen
