Old 10-15-2011, 07:27 PM   #1
Exterior caulk
I was going over my trailer after returning home from our latest trip. I moticed cracked caulking several places on the corner trim pieces that run down the front and back of the trailer. I also noticed cracked caulk around the fender skirts. I think I want to attemp to remove the cracked areas and recaulk. Any suggestions on removing the caulk? Is standard window and door silicon acceptable for the repair?
While on the roof, I noticed lots of cracks in the Dicor. I guess I will go get a couple of tubes to get me to spring and then Eternabond tape the roof. The unit is a 2008 and I don't see applying Dicor every few years instead of long term repair with the tape.
jamesp is offline   Reply With Quote
Old 10-15-2011, 08:58 PM   #2
grhodes50's Avatar
I have used the Pro Flex on the exterior of my tt.
You can find it here; 10oz PRO FLEX RV WHITE - RVWholesalers.com RV Parts and Accessories or probably at your dealer.
Gary & Trish
2019 Nights Camped - 3
Old 10-16-2011, 10:02 PM   #3
Koodog's Avatar
Agree with Gary....Pro Flex works very well.
Walt-N-Terry Sanford
03 Dodge Ram 2500 Diesel
08 Rockwood 8317
Koodog is offline   Reply With Quote
Old 10-17-2011, 07:27 AM   #4
RV Newbie
buzzards27's Avatar
Chances are it is only a cosmetic issue. In most cases the real seal is below the surface, where the pieces are joined.
If you are going to tackle it warming the old caulk should help. Cutting out the old with a sharp knife and or a chisel works well. Slow and steady, it will take a while to do without damaging finishes.
Whatever you use avoid something that does not skin over quickly. The prior owner used something that remained tacky and it picked up a lot of dirt.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
