Old 06-24-2017, 06:02 PM   #1
Exterior door too stiff
Our new toyhauler has these new style entrance doors ( I don't even know what they are called) that do not swing freely. Instead they have some sort of built in resistance so they aren't ripped out of your hand due to high winds. Anyway, the front door works fine, modest effort to open or close it and it will "park" at any position. But the second door takes too much effort to move and I can sense the pressure on the hinge screws and door frame.
Does anyone have experience with this type of door and is there any adjustment available to change the amount of force required to swing the door?
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
larrytbm is offline   Reply With Quote
Old 06-25-2017, 12:17 AM   #2
Moparman1230's Avatar
Those are called friction hinge doors. They're purposely "stiff" so you don't need the "hold open" arm to hold the doors open and they'll stay wherever you want then too. As for adjusting, I really don't know. I haven't had a problem with mine. They might loosen up a bit through use.
"Do, or do not, there is no try." - Yoda
2017 Cherokee 294BH
2015 Ram 2500 4x4 6.4L V8 Crew Cab
Moparman1230 is offline   Reply With Quote
door, exterior
