Old 06-08-2015, 06:40 AM   #1
waiter21's Avatar
Exterior Frig Access cover leaks water - major water damage
If you have one of these covers, you may want to look at it carefully to see if water can leak into your frig compartment.
When we purchased our "New to Us" Mirada, One of the major reasons I was able to negotiate a great price was because of the water damage under the frig.
The weather finally warmed up enough to find the cause, repair it and also repair the water damage.
Repairing the hatch cover frame to prevent further water intrusion. Adding a lip to the bottom of the access cover frame:
Fixing Frig exterior access panel door leaks | 2001 Coachmen Mirada 300QB
Repairing the water damage. The red outline shows where all the wood was rotted away from years of water intrusion.:
Repairing Delamination and water damage | 2001 Coachmen Mirada 300QB
ID:	79389   Click image for larger version
ID:	79390   Click image for larger version
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
cover, exterior, water, leak
