Old 09-03-2019, 12:10 PM   #1
LouNick's Avatar
Exterior Light -How Do I Get Inside?
I have a 2014 Forest River Ultralite 5er model 8289 WS with two exterior side light fixtures that I canít figure out how to get into.
One of them is leaking, and before sealing the outside, Iíd like to open it up and dry it out.
Obviously, there needs to be access to change the light bulb, but how?
Any advice would be greatly appreciated.
Lou & Paula
2014 Rockwood 8289WS Ultra Lite w/Reese Revloution Pinbox.
2011 F250 Power Stroke Super Duty King Ranch Super Crew w/Reese 16k Fixed Hitch
LouNick is offline   Reply With Quote
Old 09-03-2019, 12:17 PM   #2
Typically, most of them have a small tab on the lens holding them in on either the top or bottom. You would just need a small screwdriver to pop them out. While you are in there, replace the bulb with an LED.
Here is one:
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 09-03-2019, 12:35 PM   #3
LouNick's Avatar
Here is one:
SUCCESS!
Thank You!!!
Lou & Paula
Old 09-03-2019, 01:16 PM   #4
LouNick's Avatar
Originally Posted by LouNick View Post
SUCCESS!
Thank You!!!
Now it is quite obvious that the bulb compartment of this fixture was never intended to be waterproof. No gasket to be found under the lens.
Thanks again.
Lou & Paula
exterior, light
