Old 04-12-2019, 09:05 AM   #1
Vince and Charlette's Avatar
Exterior panel removal
I need to gain access to repair a furnace. (Can't get to it from inside.) The exterior access panel and surrounding area are painted and finished with clear coat. The panel is held on with screws and some form of adhesive, calk or sealant. Try as I may, it seems impossible to get off. Has anyone succeed at something like this? Ideas welcome.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 04-12-2019, 09:08 AM   #2
007matman's Avatar
We can't view your attachment.
Is that a photo? It may help.
007matman is offline   Reply With Quote
Old 04-12-2019, 09:23 AM   #3
cavie's Avatar
Try sliding some tooth flaus or builder string behind the panel and pull down using a back and forth saw motion. First one I have heard if that wasn't accessable from the inside. but then we are talking about a motorhome here.
You will probably have to remove the chrome vents first. That too will be hard to remove. string won't work on that it has 2" pipe extention behind the openings. Putty knife, screwdriver.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-12-2019, 09:35 AM   #4
Good idea Cavie. I'll give it a try. (BTW - Furnace is built into and under the bathroom cabinet. Front furnace easy to remove from inside. It doesn't even have an external access panel. But not so with the back.)
2018 Berkshire 38A
Old 04-12-2019, 09:37 AM   #5
you need to pull the inlet/exhaust first . and there is a screw under there also . then a razor around the edges and it should come off
MR.M is offline   Reply With Quote
exterior
