Old 05-03-2015, 08:50 PM   #1
Fiberglass exterior wall chip repair?
I did exactly what I wanted to avoid - I chipped the exterior wall when installing shelving on the interior of the trailer.
I carefully measured the length of the hollow-core door anchors in comparison to the gap between the interior and exterior walls. After installing one anchor I checked the outside wall and all was good. Then I merrily installed the others and used the screws that came with the anchors. Bad idea.
While the anchors are okay to use, the screws are not. I didn't drill all the way through the wall but I did chip or dimple the exterior gel coat on every screw.
What hope do I have of repair, if any?
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
Old 05-03-2015, 10:03 PM   #2
Oklahoma Proud
MillerTime's Avatar
Evercoat or West marine has a gelcoat paste kit with tints. I would use that to fill in the chips. Then you could lightly sand it flush and buff the sand scratches out.
Good luck!
ID:	76091   Click image for larger version
Old 05-03-2015, 11:48 PM   #3
Thanks. I'll check it out.
exterior, fiberglass, repair
