Old 06-28-2017, 12:05 PM   #1
Flex seal roof
Has anybody used "flex seal" to repair a leaky roof?
RustyKY is offline   Reply With Quote
Old 06-28-2017, 01:08 PM   #2
Just as confused as you
Scrapper's Avatar
Use Eternabond. As long as you follow the directions it is guaranteed to work.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 06-28-2017, 01:08 PM   #3
007matman's Avatar
Looks like a band-aid repair product. What's the problem you're trying to fix? Photos help.
007matman is offline   Reply With Quote
Old 06-28-2017, 01:12 PM   #4
Rusty... Rusty... don't believe the TV pitch man!
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 06-28-2017, 01:59 PM   #5
Leaking around skylight in the bathroom.... look like the caulking needs to be replaced....
My plans are to remove the caulking and replace....
I was hoping the flex seal would work until I have time to do the repair.
Old 06-28-2017, 03:17 PM   #6
007matman's Avatar
The Dicor that is likely sealing it up now is actually fairly easy to remove with a putty knife. Just make sure you don't damage the roof taking it off.
Then just clean up and apply new Dicor. I did both bathroom pipe vents and a small repair to my skylight seal in about 20 min on the roof.
It's not hard at all to do. I wouldn't use a paint on patch as that could likely be even more difficult to remove and repair properly later on. If you're looking for a temporary fix you could always use a small tarp (or plastic) and duct tape. Any residual tape can be removed using denatured alcohol.
roo, roof, seal
