Old 02-09-2018, 02:35 PM   #1
Flex shot
Has anyone here used flex shot on Rv doors, windows and trim? NOT THE ROOF! I was wondering if holds up to hot as hell To freezing temps without cracking in a year. Main reason is you can save it and use later and looks easy to use with aerosol can. Probably hell to get off but thatís ok with me if it is a good permanent fix. Thanks.
quick83 is offline   Reply With Quote
Old 02-09-2018, 02:43 PM   #2
ben31's Avatar
I've used flex seal on some things on my house. I would never use it again. The areas were subjected to constant UV (sun) and the flex seal broke down within a few months. I would use sealant made for RV use. In this case some DiCor non-self-leveling sealant.
It may have worked for others, but to me, it was a waste of money and time.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 02-09-2018, 02:48 PM   #3
Thanks!! I use only dicor self level on the roof and Rv caulking everywhere else. (Pro flex) It does not hold up in some spots, ie it pulls away or splits after a season. Maybe Iím expecting to much.
Old 02-09-2018, 03:10 PM   #4
Prime Member
It's good for an immediate short term repair until you can do something more permanent.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
