Old 08-16-2013, 08:06 AM   #1
Forest River A/C Housing
I need to remove my a/c housing to check on the roof seal. I have removed the 4 bolts holding the housing to the cooling unit but I can't seem to detach the 2 pieces of the housing.
There are small built-in push-down holders or "clips" but these do not seem to release the front and back sections. It can't be lifted straight up because of the front nose design that holds the front section in place....
I wonder if they are glued together or maybe i am just babying these holders for fear of breaking something....
Any suggestions? Garry
Garry Logue is offline   Reply With Quote
Old 08-16-2013, 08:12 AM   #2
TURBS's Avatar
What a/c unit do you have ? Year?
My 2011 13.5k has at least 10 screws holding cover on.
Old 08-16-2013, 08:16 AM   #3
It's a 2010 Mini-Lite; 4 screws only and these came out easily. It's the two sections of the housing that won't come apart, thanks for your speedy reply though! Garry
Old 08-16-2013, 01:11 PM   #4
Wanna Be Camper
SaskCampers's Avatar
If it is like my Coleman, I just took the 4 bolts out then lifted it up backend first then slid the cover forward and it came right off. You have to work at it abit but it does come off pretty easliy.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 08-20-2013, 12:50 PM   #5
Dallas Texas
TexasBBQ's Avatar
Aren't there some screws along each side? Mine has several but I'm still not sure what model AC you have. Try downloading the installation manual.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 08-24-2013, 10:08 AM   #6
Is it ok to get on the roof of a rockwood roo 17? I have to work on my ac unit because the fan has seized but I am not sure if the roof will hold me.
jlatona is offline   Reply With Quote
Old 08-24-2013, 07:06 PM   #7
Chris1304's Avatar
I was on top of mine last week and didn't fall through.. It held 210!!
Chris1304 is offline   Reply With Quote
forest river
