Old 05-21-2012, 08:48 PM   #1
Forest River contact for decals
Would anyone know who I need to contact at Forest River for some decals for our Roo..I had talked to someone before but had some health issues and have lost touch...any help would be greatly appreciated...
ashnic is offline   Reply With Quote
Old 05-21-2012, 09:12 PM   #2
Triguy's Avatar
(I'm moving this to General Tech and Repair)
I would think your dealer would be best to go through. You could try FR parts and service, though. I don't have the number for them, but you could try and Google it or maybe someone here will post it
Either way, you will need to give them your VIN. Pictures are good.
Good luck and let us know what happens.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-21-2012, 09:14 PM   #3
Thanks...I just located my old email and dropped them a email...my dealer..one of the largest in Ohio..can't get anything it seems..actually they recommended I contact FR...so I have..Thanks
Old 05-21-2012, 09:16 PM   #4
Triguy's Avatar
Great. Let us know who you contacted. This comes up every so often. Thanks
Scott
2012 Shamrock 233S
Old 05-30-2012, 12:45 PM   #5
you can call (574) 534-3167 and ask for parts... you'll need your VIN number.
whanner is offline   Reply With Quote
Old 09-25-2013, 12:42 PM   #6
The two larger decals for the front bunk doors are $61.20/decal. Contact Sheri Dunlap at sdunlap@forestriverinc.com
http://www.flickr.com/photos/nickgne...7635885586186/
nickgnelson is offline   Reply With Quote
Old 10-30-2013, 12:29 PM   #7
Decal replacement information
Hello: I've had the same problem with my 07 Flagstaff 5er. Here's the Contact Information I used to order new decals. They are about $25. each, I think and they are the exact ones they used at the factory. You just give them the model number of your trailer or the vin #. I've done this about 3 times now and never had a problem. As for replace them, it's not a big deal. I use a product called "Stoner XENIT" All you do is spray it on, wait a couple of minutes and then scrape it off. I use a very sharp putty knive and the decals comes off in long strips with no problem. The only trick is to make sure you knife is perfectly flat again the trailer so you don't gouge it. I've never gouged my rig and I've done it about 4 times now. Oh. Just be careful when spraying that it doesn't get on decals that you don't want to remove. They will email you a sheet showing all the decals that you trailer needs with the item number, you just pick the ones you need.
Here's the info: Good luck.
KEAIRA SMITH
Forest River
Lite Trailers- 5th Wheels & V-Lites Parts
574-642-2640 ext 107
574-343-5938 Fax
Thank you,
TWO4THEROAD is offline   Reply With Quote
