Old 03-21-2016, 04:54 PM   #1
fireman1317's Avatar
Gray spray foam
I noticed a couple exterior areas on the frame of our TT that it looks like a gray expanding foam was used to seal some areas. Is there anything special to this foam as opposed to the Great Stuff foam that I can buy a Lowes or Home Depot? There are a couple of good size holes that were cut to run small water lines in the outdoor kitchen area. Didn't know if I should try to find the gray stuff to seal that or not.
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 03-21-2016, 05:14 PM   #2
Ford Idaho's Avatar
I would not have an issue with the big box stuff, while there get a can of gray spray paint and match it out....
Old 03-21-2016, 06:07 PM   #3
I've used Great Stuff under the camper to fill the same kind of holes. Even used it inside to fill the 4" hole the galley and bath sink drain pipe goes thru the floor . Careful, that spray foam can be a mess to work with. Don't ask me how I know this. I would suggest wearing disposable gloves and your oldest clothes. I've found when exposed to sunlight it will break down after several years. And forget about saving any unused portion, the nozzle will clog.
Old 03-21-2016, 06:15 PM   #4
northstar1960's Avatar
The Great stuff is fine to use , As mentioned the sun does effect it, and can be a mess if not careful .
northstar1960 is offline   Reply With Quote
Old 03-21-2016, 07:49 PM   #5
Old 03-21-2016, 08:27 PM   #6
tjm
I prefer to use the spray foam with the pest block for a little added benefit.
Sent from my iPad using Tapatalk
tjm is online now   Reply With Quote
Old 03-21-2016, 08:39 PM   #7
I just picked up some Great Stuff - Water and Stone. It's for ponds and waterfalls and is Black. Haven't used it yet.
halliday is offline   Reply With Quote
Old 03-21-2016, 09:09 PM   #8
Thats a good idea. I'm also considering getting some of that copper mesh to place over the hole before I cover it with foam.
