Old 12-04-2019, 05:08 PM   #1
Has anybody tried Flex Seal spray in place of caulking?
The metal skirting buckled a little from the hot sun on one spot on my 5th wheel. I added a couple of screws to pull it back in and now I need to seal the seam where it pulled away from the side wall. I'm wondering if I should try using the clear Flex Seal spry instead of caulking. I hate caulking and don't have a lot of patience with it and usually end up with a mess. I thought I could tape above and below the seam and use the spray. With that I could get it down into any voids between the skirt and sidewall. I've used it in other applications and seems very durable but is hard to get it on smooth. I have found the spray to be as hard to remove as their tape.
I thought if anybody has tried such an application you might share your experience and any tips you may have.
2018 Columbus 366RLC
2015 Silverado 3500 6.0 Gas Hog
10Ranger is offline   Reply With Quote
Old 12-04-2019, 05:13 PM   #2
cboss's Avatar
I've had minimal luck with Flex Seal Spray.
It might be OK to spray your area, let it dry, then caulk over it.
Tape off the area before you caulk and you can get a really nice smooth line of caulk.
Use a good exterior CLEAR caulk and you will never see it.
Good Luck!
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 740
cboss is offline   Reply With Quote
Old 12-04-2019, 05:16 PM   #3
cavie's Avatar
If you use Clear Flex Spary I hope you like the color yellow. After 4 months on my house this is what I came home to. Use non silicone caulk.
Name:	flex seal 2.jpg
Name:	flex seal 1.jpg
Name:	flex seal 3.jpg
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 12-04-2019, 05:34 PM   #4
cavie's Avatar
Good Luck!
See post #3
Old 12-04-2019, 05:40 PM   #5
The Flex Seal commercials sound too good to be true.
You know what they say about that.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 12-04-2019, 08:44 PM   #6
rracer5's Avatar
Tried white Flex Seal on a 1/4" slit on the edge of my slideout roof material. Looked great for a while then I noticed it turn yellow, dry out and cracked!
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-05-2019, 12:26 AM   #7
dbledan's Avatar
If you dislike caulking would you consider eternabond tape? It would not yellow over time and less mess and when applied properly will last a lifetime. Just make sure the area does not flex too much and you clean it well before applying.
dbledan is offline   Reply With Quote
Old 12-05-2019, 12:47 AM   #8
rsdata's Avatar
go to the HomeDepot or Lowes... look around the caulk isle, they now sell great little plastic/hard rubber tools that allow you to scrape excess caulk and make it look professional... use clear or white or whatever color you want, but get Latex, not silicone, cut a small angled tip on the end of the caulk tube and do not put too much on... use the tool to scrape the excess and leave a nice clean application
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 12-05-2019, 07:19 AM   #9
Bill and Gail's Avatar
I had trouble with the siding on my s&b last year, I tried a clear product called Lexel, found it in Lowes by the caulk. It is still clear.
Bill and Gail is offline   Reply With Quote
Old 12-05-2019, 07:58 AM   #10
Semperfi24's Avatar
X2 on what Bill and Gail said. In my experience, Lexel is awesome.
_________________________
2019 Ford F250 Lariat 6.7 Powerstroke
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 12-05-2019, 10:13 AM   #11
Flex Seal has a poor reputation, but I suppose that it will work perfectly...
Until the first rain
joshuajim is offline   Reply With Quote
Old 12-05-2019, 10:25 AM   #12
frank4711's Avatar
x2 ..........
Frank & Cindy ... Rockwood 2888WS Ultra Lite 5th Wheel---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed---Remi & Sage camp pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Goodyear Endurance ... Predator 3500---48 days 2019---Payload 4394
frank4711 is offline   Reply With Quote
Old 12-05-2019, 11:00 AM   #13
Their TV ads alone are enough to make me want to buy SOMETHING ELSE.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-05-2019, 11:09 AM   #14
Georgia Rally Coordinator
aceinspp's Avatar
I've use it on one of my water features that started to leak has worked perfect but I also sprayed the brown color paint to it to brighten up the fountain. Been working for a year no more leaks. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 12-05-2019, 11:23 AM   #15
Flex Seal
Flex Seal is no good, it peels soon after application and is not waterproof
Matheny9 is offline   Reply With Quote
Old 12-05-2019, 01:21 PM   #16
I thank you all for your input. I would say the opinion against using the Flex Seal is overwhelming. I will take the suggestion to use caulking and I appreciate advice of how and what to use.
I have used Eternabond on the roof but I don't think it's the proper application for this situation. I have used Flex Seal tape to repair cuts I had to make in the Coraplast underbelly and to hold a piece of trim on until I could get into a shop for repair. I found that the Flex Seal is every bit as good as Eternabond for most situations. I wouldn't be surprised if I learned they were made in the same factory.
Old 12-05-2019, 02:49 PM   #17
It is a waste of money. Does not WORK
cm-gibson is offline   Reply With Quote
Old 12-05-2019, 03:25 PM   #18
When working with caulking and you want a nice smooth application, I use my finger to smooth it out. You will also need a small container with water and lots of liquid soap in it. The caulking will not stick to your finger if you first dip your finger in the water and soap solution. Old trick I learned in the aircraft industry.
Walholler is offline   Reply With Quote
Old 12-05-2019, 03:55 PM   #19
On forward end of my 2017 25 pack 12 ...damp in bedroom overhead closet...opened everything up put electric heat in to dry closet wallpaper....discovered cracks in caulking at joint between exterior overhead roof canvas and metal flashing up from hitch area. Used complete can of '' Clear ' to seal it.." !....3 coats n let it dry well....CAUGHT PROBLEM IN TIME !
Buuuuut......the stuff dries out and granulates away after 40 days of solar exposure. BUT IT DOES WORK
juice5 is offline   Reply With Quote
Old 12-05-2019, 04:04 PM   #20
So you are saying it does work... but only for 40 days?
What good is that?
Days Camped: '17=30 '18=51 '19=58 '20=14
caulk, seal
