Old 02-01-2017, 06:32 PM   #1
nexcompac's Avatar
Help! I'm pealing...
We noticed this winter that our paint on the front of our TH is pealing, and pealing bad....
Two questions:
1) why would the paint just start pealing? What could be the cause so as to prevent it from happening more?
2) what can I do to repair or fix it? Someone suggested I should rattle can the paint. I was thinking of getting some logo sticker or something to place on top to A) stop it from pealing more and B) cover the damage
Thoughts??
26' Forrest Sierra Toy Hauler
26FBSP
Pulling toys for my boys!
nexcompac is offline   Reply With Quote
Old 02-01-2017, 06:39 PM   #2
Left Coast
Decals do wonders.......might of had a blister there....
Old 02-01-2017, 06:44 PM   #3
rmac04401's Avatar
Not primed, bad adhesion when painted, those spots were not properly/missed prepping well before spraying? Could be some reason. Some very fine wet sandpaper and some primer and white paint it may blend well. I had to fix a spot on my old Fleetwood where bikes had worn through paint while transporting on rear bike rack. No one could notice unless they were really looking for the repair.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 02-01-2017, 06:49 PM   #4
nexcompac's Avatar
Did you rattle can the paint? What kind and what primer did you use?
26FBSP
Old 02-01-2017, 06:55 PM   #5
rmac04401's Avatar
Yes rattle can paint from Walmart and regular light primer from Walmart. Checked can cover against paint to be sure it matched. You could also maybe take a sample of the peal to Lowes to have them color match. My spot was small and on the back but was right at eye level.
2005 Honda VTX 1300
Old 02-01-2017, 06:58 PM   #6
Looks to me like it was painted over the original paint. That does not look like primer under the peeling paint. Probably not sanded and primed before hand.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 02-01-2017, 07:04 PM   #7
Crusadernoob's Avatar
Piss poor preparation is why paint peels like that, more than likely it would continue on that panel. I would really be trying to peal all I could before I put something over it.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 02-01-2017, 07:49 PM   #8
silver's Avatar
Don't use a rattle can from Walmart. Take something like your hot water heater door to a shop that specializes in auto paint. They can mix a custom rattle can that will match perfectly for about $10 to $15. Well worth the money. They will even tell yu what to treat the aluminum with so it will stick.
silver is offline   Reply With Quote
Old 02-01-2017, 07:54 PM   #9
Left Coast
That's exactly what I did for a J moulding...
Old 02-01-2017, 07:56 PM   #10
Left Coast
Old 02-01-2017, 08:08 PM   #11
First, not that it matters but it does... it is peeling not pealing.
Looks to me like the original paint was painted over. It sure looks like there is a stripe in the lower blister. Who knows why they painted over it? Maybe damage repair or water leak that is still leaking and blistered the paint??
None the less you should look into it. I don't think I'd be wanting to put a decal over the problem areas without knowing for sure what's going on.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 02-01-2017, 08:56 PM   #12
Oklahoma Proud
MillerTime's Avatar
Looks like the original paint to me. (Im in the paint and body industry)
I bet there is a paint warranty on the sheet metal its self. But good luck finding out who that manufacturer is. ( Most all painted barn tin has a __ year warranty, and yes i know this isn't the same )
You all realize this aluminum sheet metal is made from a big roll of sheet metal that is painted and stamped in a metal manufacturing facility. Its not primed. Most likely its acid washed and then painted.
OP. I would power wash or take an air blower and blow as much paint off as you can.
I would then feather out the remaining paint edges with 320 sandpaper. If you want to spray bomb it, you can do that, or shoot it with some decent single stage paint like Omni or Imron.
Either way you need to use an acid etch primer on the bare metal. Just one light coat, it just needs to bite in to the metal.
Then you can prime, seal and paint. The sealer is a critical step, otherwise the paint will "bullseye" or ring out, which is where the paint just dies back into the existing paint edges and you will see sand scratches in the paint.
Good luck!
