Old 03-12-2017, 02:01 PM   #1
Help needed identifying horizontal trim on 2014 Freelander 29qb
Hi -
We are new owners of a used 2014 Freelander 29qb.
There are horizontal trim pieces on front of coach and above side storage.
The inserts are broken or brittle and I'd like to repair them. There are white plastic end caps holding the molding in place. I'm attaching a photo.
This isn't the same type of molding as on the corners (in the photo attached, that type - a wider, flexible, vinyl insert type - is seen on the vertical corner of the coach)
I don't know what these horizontal trim pieces are called, so I'm not sure how to order replacement parts for the inserts.
If anyone can shed light on what these are? and a source for replacing the broken pieces?
Thanks!
Joanne
jbriopelle is offline   Reply With Quote
