Old 05-21-2012, 05:23 PM   #11
Originally Posted by TexasBBQ View Post
James - You can have them make the bubble a little taller to make more durable if you're ever in a hail storm. In central Texas hail storms are fairly common.
Don't forget to add pics of your replacment. Good luck.
Thanks Texas! I am going to call and ask if they can make a 5 inch bubble instead of a 3 inch... you are right, that would add a little more strength to the structure as a whole.
James
2005 Excursion Limited dragging a 2012 Roo 233s
DSN46 is offline   Reply With Quote
Old 05-21-2012, 05:27 PM   #12
Originally Posted by lbrjet View Post
They are cheap but I don't think it should have cracked. It can rain with the sun still shining bright down there and the same thing could have happened. Maybe the location of the holes is putting stress on the skylight.
THIS is very much a possibility. One thing I did notice: the guy (or gal) who installed the skylight on my camper that day must have been drunk, or just didn't care. ALL of the screws are "zipped" into the roof at all kinds of leaning over angles and such.... crooked as can be. I followed the same exact holes putting it back on because I didn't want to start a new hole right next to the old hole and then have the screws wiggle. It may well be that they are putting stress on the inside of the holes through the skylight plastic. Great point!
James
Old 06-04-2012, 12:43 PM   #13
Dallas Texas
TexasBBQ's Avatar
DSN - How did the replacement go?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 06-04-2012, 09:16 PM   #14
Hey Texas!
I have put Eternabond tape over the crack for now.... FR is sending yet another skylight out to me... have not made up my mind as to whether I will risk it again with OEM part, or go for aftermarket of better quality.
Thank you for remembering! I didn't forget this thread... I just haven't acted upon it yet. I will post up how the 2'nd replacement goes when I do it.
James
