Old 04-18-2013, 02:58 PM   #1
Help with spongy floor
I have a 2000 Flagstaff 25' pull behind. The floor in the front entrance way became spongy. I pulled up the flooring and found that it was wet and rotted. The styrofoam had broken up in the entrance way. I have checked the roof for holes and can't find any. I purchased a tube of Dicor and sealed any place I could find that water might be coming in. I tightened the hold down bolts for the a/c. It's still leaking!!! I've checked and caulked around the windows. Anyone have a suggestion??
mtnpapa201 is offline   Reply With Quote
Old 04-18-2013, 03:00 PM   #2
Triguy's Avatar
I don't have an answer for you, but I did move your post to its own thread so it would not get lost.
Good luck!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-18-2013, 06:23 PM   #3
Haulin' Camp
KewlKamperz's Avatar
We had a soft floor problem in a previous camper. We finally figured out that there were some small holes in the underside of the trailer that allowed moisture to get in. When we traveled in the rain, water would splash onto the undercarriage and penetrate the holes. DH repaired the floor and used some sort of automotive undercarriage spray that he bought from Home Depot.
2012 Salem 26TBUD
2015 Nissan Armada
3 Kids
2 Dogs
KewlKamperz is offline   Reply With Quote
Old 04-18-2013, 06:37 PM   #4
Professional Texan
TexasBob's Avatar
In my last trailer I spent a lot of time looking for a leak, ran a water hose on the roof as I looked, re caulked everything that whether it looked bad or not. Finally I found two leaks, 1) around a tail light and 2) around a side marker light.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 04-19-2013, 12:36 PM   #5
Thanks for both of your replies. I forgot to mention that the water seems to be coming down the inside the wall where you can't see it and coming out under the sofa, fridge, stove etc. I'll keep spraying water and looking. This happens when the camper is stationary.
Old 04-19-2013, 12:43 PM   #6
Professional Texan
TexasBob's Avatar
Often there is no correlation between the where the water is getting in and where it is showing up.
I once had water in a back storage area, the water was entering from a roof seam in the front of a 28 foot trailer, so spray water everywhere.
Texas Bob
