04-05-2013, 06:52 AM
Holding tank vent
Anybody use a swivel roof vent for their holding tanks? One is called Clclone, that supposedly prevents any gasses from entering the cabin. They're also a money saver because, again supposedly there's no need for tank chemicals. At least that is what's being said by a salesman.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
04-05-2013, 07:39 AM
Imho they only work when the toilet is open for a brief second.
99 percent of the time they just sit up there and rotate.
You have a closed waste system therefore it can and only will work when the toilet valve is open during flushing.
Pass.
Turbs
04-05-2013, 07:45 AM
The vent
Pass.
Turbs
Thanks. You saved me some $$$. That may explain why only the salesman has one!
Duramax/Allison
04-05-2013, 07:47 AM
You will still need chemical. Preferably the GEO method.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
04-05-2013, 07:49 AM
Hey they tell (Wind Direction),and if you use a metal one and run a ground wire they double as a (Lighting Rod)! Youroo!!
04-05-2013, 08:27 AM
Phat Phrog Physician
You could also put a colorful propeller on top for hours of free entertainment.
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
04-05-2013, 08:37 AM
Doc
Strobe light?
04-05-2013, 10:16 AM
Strobe light?
...or one of those annoying wind-whistle doohickies.
Doc
Ron, Amber & Jordan
04-05-2013, 08:26 PM
Got one for free and it still wasn't worth it....could not tell any difference from before it was installed...IMO save your money and buy some beer.
04-06-2013, 02:44 PM
I got one real cheap, put it on and only notice a difference when we stop for breaks while traveling. Not worth $.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
04-06-2013, 02:51 PM
I have one on my 5er. When it's windy, it acts as a venturi and creates a vacuum therefore pulling the gases and smell out of the black tank.
04-06-2013, 02:59 PM
Imho they only work when the toilet is open for a brief second. 99 percent of the time they just sit up there and rotate. You have a closed waste system therefore it can and only will work when the toilet valve is open during flushing. Pass. Turbs
This is about 4 or 5 times in the last week I have to agree with Turbs. (Something is wrong here) And, for them to work, you have to have a wind when you flush or otherwise they do nothing. Totally useless!
They are just a trinket like Herk's banana slicer. Altho' the banana slicer comments are comical.
04-06-2013, 03:10 PM
I have to disagree with you OC & Turbs. All it needs is wind to work. You don't have to flush. The pipe from the black tank to the vent is open all the time. When the mess in the black tank is breaking down it creates heat which will go up the vent pipe. With the venturi effect working when it's windy, it will pull the gases out. Notice I did say windy. That's why there is a vent in the 1st place. It does work for me. My 4.5 cents.
04-06-2013, 03:25 PM
Beg to differ, there are no chemicals in a black tank like in a septic tank to cause a chemical break down of the material and it is a closed system just like an empty bottle with the top off. With wind blowing, there will be little if any vapors coming out the vent or the empty bottle sitting in the wind.
BUT, if you like them, by all means use it/them. Just my take on it.
04-06-2013, 04:17 PM
Well OC you have got me all excited and I reached for my R&C and promptly spilled it onto the keyboard of this computer. All is fine just sticky. I'll agree to disagree with you. Hows that???
04-06-2013, 04:20 PM
Sounds like a winner to me. Like I said, if you like them and think they work, all the better for you. I'll save the few bucks and buy tires as bad as I hate to.
04-06-2013, 04:40 PM
I haven't experienced it with my Cedar Creek, but I had a pull behind that would allow fumes to escape during a flush when the weather was hot and the tank was over 1/3 full. I had to do something to keep the DW happy and I didn't think the rotating vent would do the trick. I installed a little fan called a 'Lil Stanker'. Lil' Stanker™ In-Line Deodorizer Fans
That sucker (pun intended) worked great! A happy wife is a happy life!
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
04-06-2013, 05:06 PM
Denver, CO
X2. Having a slight neg pressure on the system does help IMO. I kinda think they are pretty nifty.
The tank and vent are always aspirating some air due to temperature changes, expansion etc so it does help to always have the air flow out the top.
2017 Fuse 23T
04-06-2013, 05:22 PM
Since we never had a problem such as the kind this device is supposed to prevent I will pass.
BTW - correct name is Cyclone
04-06-2013, 05:25 PM
Only when you flush the toilet!
Otherwise its decoration.
