12-06-2017, 07:52 PM
Who Dares, Wins
How do you lube your seals with slide toppers?
As the title suggests... Did some slide seal lube the other day before the trailer was put away for the season and figured there had to be better ways to lube the seal across the top of the slide under slide toppers. I used a telescoping car wash brush with a sponge duck tapes to a tire brush... It worked but someone must have a better way?
2015 Chevy HD D-Max
2022 Impression 315MB
12-07-2017, 02:29 PM
6' aluminum pole with shaped plastic insert, also have a 6' extension. Plastic shaped insert wrapped with 6 x 9 gauze pad tie wrapped on.. saturate it with 303 and drag across the outside and then slip underneath seal and do it again. Work it from both ends of the slide if need be
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
12-07-2017, 02:36 PM
I pull my slide in about 6" and stop.
Then I go INSIDE and use a step stool to access above the slide.
Using a microfiber cloth with 303 Protectant, I can slip my fingers and the cloth between the slide out roof and the seal and wipe/treat the entire seal in about 1 minute.
Done! No poles, no duct tape, no fuss, no muss.
12-07-2017, 02:44 PM
There ya go Doc, one of those methods should giter done!
14K Equalizer
12-07-2017, 05:58 PM
Who Dares, Wins
WHat is that insert? Or is it home brew?
You know that NEVER dawned on me to try... I will give that a whirl!
2015 Chevy HD D-Max
12-08-2017, 03:54 PM
I use Silicone spray for my lube. Able to crawl under my slide topper about 1/2 of my body, then I run into the skylight.
12-08-2017, 04:23 PM
Which 303 Protectant do you use?
12-08-2017, 07:21 PM
Never did mine...waste of time and money in my opinion !
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
12-08-2017, 07:57 PM
2007 WildCat 32QBBS
I use the spray can that shoots a stream of foam. I can hit the seal from either side. I'm usually not that concerned with the top one anyways since it's protected from sun and rain. The side seals I usually hit twice a year.
12-08-2017, 10:42 PM
Novice Travel Trailer Guy
Agreed
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
12-09-2017, 12:27 AM
Canadian Member
I use this.
https://www.protectall.com/shop/slid...eal-treatment/
I spray it on a cloth and wipe as far in as I can reach from the sides. I may try some of the ideas posted here.
12-09-2017, 09:36 AM
An old sock taped onto a painters pole !!!
