Old 05-06-2019, 03:19 PM   #1
beerfor2's Avatar
How much caulking??
My trailer is two year old and I am starting to notice cracking and pulling away in a lot of areas on the exterior vertical surfaces. However I am unsure as to how many tubes of caulk I may need, would hate to run out in the middle of the Job. I plan on resealing most if not all of the exterior walls (not roof). My Cherokee is 29'. Thanks!!!
2017 Cherokee 294bh
2014 Ford F-150 3.5 ecoboost
beerfor2 is offline   Reply With Quote
Old 05-06-2019, 03:21 PM   #2
BandJCarm's Avatar
Get about 4 tubes of clear Geocell. Whatever is left over, keep in storage in case of any leaks, etc.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-06-2019, 03:36 PM   #3
I bought two tubes of ProFlexRV (clear) and touched up mine.
I didn't even use one tube but I didn't have to do every seam along its entire length. Just where it was needed.
A little goes a long way.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 05-06-2019, 03:37 PM   #4
007matman's Avatar
Agree with BandJCarm.
You'll probably only use one on your repair. However, by the time you need to use it again it'll be dried out (I don't care how you cap it off). Then you still have 3 more unopened tubes.
It's cheaper on Amazon to purchase several at a time.the biggest pain is not having it when you need it. I travel with one too just in case.
007matman is offline   Reply With Quote
Old 05-08-2019, 09:43 AM   #5
GLBCamper's Avatar
g]
Can you just touch up without removing existing first? The factory caulk looks more like silicone but I bought the geocel to repair and would love to just touch up instead of scraping all the old out, even if it is still solid.
2016 EVO (Sonoma) ATS 201rd 24’ TT
2016 F150 4x4 Sport
GLBCamper is offline   Reply With Quote
Old 05-08-2019, 09:46 AM   #6
If I buy one, I end up needing three. If I buy three, I end up using half of one.
Rather have two many....than not enough.
TheWolfPaq82 is online now   Reply With Quote
Old 05-08-2019, 05:07 PM   #7
You can if it isn't silicone. I do but mine isn't silicone.
Silicone will not seal to itself once cured.
Old 05-08-2019, 06:05 PM   #8
Lexel is another great alternative. It's not silicone, never fully hardens so it provides great elasticity, sticks to itself so can be touched up, hell it sticks to everything. Stuff is super clear too. It's all I'll ever use.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
caulk
