Old 06-14-2015, 07:56 PM   #21
Based on my experience with CW, if you have them do the roof, they might forget to put the new EPDM on ....
happywhencamping is offline   Reply With Quote
Old 06-15-2015, 08:08 AM   #22
Rubber roofs on rv's
Originally Posted by 305RESGUY View Post
Just had a "Rhino" Roof installed on my RES305. It's the same material as a Rhino bedliner for a truck. The dealer said the cost is the same as a traditional roof but the bonus is "no maint ever required". It was $5600 and change. Over $5K was labor!
For anyone needing to replace the rubber roofs should not bother with the standard roof and just go with the Rhino roof stated above or there are other (spray on roofs) available.
If you do a internet search, or look in the back of most trailer life mags you will finds a number of providers and the best thing it is usually cheaper and they all come with a "lifetime"warranty. Unlike to the rubber roof which comes with a very limited 10 yrs.
SO as for the cost for your job it is way to hard to tell, you stated there are tears in the roof now (sure hope someone patched they?) but with length and damage it all varies all over the country.
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 06-15-2015, 08:36 AM   #23
My 2004 Wildcat roof is starting to show a lot of wear also but so far no leaking. Has anyone else had any experience with the roof coating BuffaloHunter mentioned above and if so what type did you use?
scrappypappy is offline   Reply With Quote
Old 06-15-2015, 12:12 PM   #24
Never Leak RV Roofing
It's a $100.00 a foot including labor and materials, new epdm rv rubber roofing, new plumbing vents, new a/c gaskets, new kitchen base and cap but does not include carpentry rot soft spots ect. Add a 20 year 100% acrylic elastomeric rv roof coating for around $800.00, but that's with a 4" fiber backed seam tape replacing the lap sealant, self leveling caulking, never have to inspect your seams again.
rvroofer is offline   Reply With Quote
roo, roof
