11-13-2013, 11:51 AM
How water proof are ADCO covers?
This is my first year with a new TT. To protect my investment I purchased a ADCO cover. My concern is how water tight will this cover be. Being concerned with my trailer being locked up and covered for the winter I decided to leave the roof vent open and a side window up about 3 inches. I am not worried about the roof vent since it has a plastic housing over it but somewhat worried about the open window. Will the cover prevent the winter elements from entering through the open window?
TV- 2018 F150 Super Cab XLT
TT- MicroLite 23FB
11-13-2013, 12:01 PM
Professional Curmudgeon
The covers are more "water resistant" than "water proof". I imagine it would be likely that the wet cover could stick to the screen and provide a wicking path for water into the interior.
I don't leave anything open to the outside. Even open roof vents allow moisture laden air in.
If moisture is a concern, you'd be better off putting desiccant inside the camper.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
11-13-2013, 12:10 PM
I keep all windows and vents closed as well. The covers are not at all water proof. They are breathable, so they and the moisture under them dries out. I think the UV protection they provide is the biggest benifit to using one. My .02
2012 F150 4x4 5.0
2011 Cherokee Grey Wolf 26bh
God Bless America
11-13-2013, 12:23 PM
I think you are fine to leave the vent open. Probably depends on the climate where you live, but I have seen several recommendations to leave the vent and a window cracked for air movement, with the idea being to prevent moisture from building up inside. On ours, I left one of the windows cracked open as well, but it is one of the tilt out windows open maybe an inch and its under cover.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
11-13-2013, 10:07 PM
The Aquashed cover is more water resistant than the Tyvek cover.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
12-16-2013, 03:18 AM
Yeah I agree I would not leave the vents or window open. My luck would be water would find its way in and ruin my TT. I just bought my first TT in August so I opinion my not count. I bought the same cover and it has been on there for a month now and the other day I went and checked on it after 4 inch snow storm and I didnt notice any moisture on the inside of my TT. There is a lot to learn about TT I just hope I don't screw something up that cost a lot to fix. I hope you guys can help me out down the road when I run into any questions.
01-07-2014, 02:51 PM
I know this reply is coming in a little late. We have the Tyvek version and are very satisfied with it. We clean up the trailer real well before covering it and it will look spic and span when we uncover it in the spring. We have covered roof vents so we do leave those open. One area of concern are the gutter downspouts. If you have the downspouts that stick out 3-4 inches on the corners you want to get you some tennis balls, punch holes in them and stick them on the downspouts. Otherwise, the downspouts will wear holes in the cover during the winter.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
01-15-2014, 07:19 PM
tennis balls are a great idea!. I used short pieces of a pool "noodle" that I then "butterflied" and secured with duct tape.
01-21-2014, 10:24 PM
I like the pool noodle idea. Punching holes in tennis balls can be risky to the fingers.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
01-22-2014, 04:32 PM
That's why they call me Nubbins.
Sent from my Kindle Fire using Tapatalk 2
2013 Roo 183
01-22-2014, 07:28 PM
I already have one of those after I lost the fight with a motorcycle chain. I wan to keep the 9 1/2 I have left.
Chuck and Joanne
