04-22-2016, 10:52 PM
I opened a can of worms..
04-23-2016, 01:59 AM
Ill be updating pictures of my progress and let this be a lesson to you all as to why sealing and caulking around lights, and corner trims as well as roof is so important.
04-23-2016, 05:23 AM
OMG!!!
Sorry for your trouble and thanks for the reminder to check the sealants around all of the lights (normally don't think of the wall penetrations like you do about roof penetrations).
Great that you have the skills to do this repair - I'm sure a dealer would charge a pretty penny for it.
By the way, what is the model and year of your trailer?
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
04-23-2016, 05:32 AM
Make sure to use a bleach and water spray to kill the mold. Big project there, but you got it
2015 F-250 FX4
04-23-2016, 08:28 AM
The model is 1998 forest river wildwood 24fb . Good tip, I have a mold killer spray that I will be unloading on the moldy areas. I went over to an Rv shop where I bought my materials and the guy there was nice enough to show me exactly what I have to do to seal it all correctly. I should be ok, hopefully and this is from corner and rear lights leak.
04-23-2016, 11:18 AM
She's coming along nicely
04-23-2016, 11:26 AM
I wonder if foam/ aluminum construction would have been better for these problems.
Warren
2014 Silverado Z71 4x4- 5.3
Flagstaff 21 FRBS
235 nights camping this past 30 months
31000 miles
04-23-2016, 11:51 AM
They do go in the cheap side when they build these things. I added extra reinforcements and wood glue which they could have used. I'm pretty happy with my work too, this wall is extra strong.
04-23-2016, 12:49 PM
MUCH better than new
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
04-23-2016, 12:57 PM
X2, good job!
2015 F-250 FX4
04-23-2016, 01:00 PM
SO sorry this happened to you! Thanks for the reminder about caulking and for posting the pics. Great job!
04-23-2016, 01:02 PM
Nope,the whole back wall would be 1pc! Youroo!!
04-23-2016, 01:41 PM
Something to be said for stick and tin construction. Yes, it can rot but it is much easier to fix.
Nice job and thanks for sharing your work with us.
2016 Jayco Eagle 330RSTS = " Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = " Hagrid"
360 degree Virtual Tour
04-23-2016, 03:24 PM
M, nice work. In disaster relief - clean up or mud out, we use a product called Shock Wave. Attached link to show you the product not to endorse a particular seller. We get it in a concentrate and mix with water, unlike the attached.
WW
Shockwave RTU - Disinfectant, Sanitizer and Cleaner (One Gallon): 8316
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
04-23-2016, 03:41 PM
Did that in more to the first trailer a 1973 Terry we bought. The fire dept opened the whole rear corner (there was no fire just a boom ). I bought it cheap and reworked it. Big job to tackle but it was how we got into camping.
Nice job !!!!! You will know much more about how campers are designed
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
04-23-2016, 06:22 PM
Been there, done that.
04-23-2016, 07:37 PM
If you ever watch Flippin' RVs on GAC you will see that they deal with this same problem all the time. Basically, they do the full repair/rebuild all the way down to the repair just like you have there. Good argument to keep those RVs inspected and sealed. Our first trailer ('54 Westate Engineering) had various amounts of leakage and rot. I caulked all of the seams (I know, too little too late), but it stopped the damage. The next trailer ('67 Shasta) had similar damage in the inside corners and around the windows. I caulked the heck out of it and used the trailer for about 6 years before someone bought it as a "Classic" in '99. I hope they rebuilt it. It was a great trailer. It needed a lot of wood replaced but could be done if someone really wanted it.
2015 Palomino SolAire 20RBS
2022 Silverado 2500HD LT Duramax 4WD
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days; 2020: 0; 2021: 10 days.
04-23-2016, 11:56 PM
I bought this trailer for what I consider a decent price and everything works but needs to be cleaned up. I had a corner trim that was detached and i couldn't screw it in cause the wood was rotted , I could have easily made it work and caulked it but dove in and to be honest I have no regrets . The 2x2s are 1.48$ each and the rest is a few dollars as well , it is work but at the end a spent a few dollars but will have a piece of mind knowing that my wall is new. I will inspect my front wall later but at this price and as cheap as it is to fix it I plan to eventually inspect the entire Rv and have it rebuilt if needed and making it a keeper since I'll know all is well, eventually. Sound nice doesn't it? It's a lot of work but truly not that bad and well worth it. I'll keep sending pics of updates , thanks for all the courage too , you guys are a great support group .
04-24-2016, 07:07 AM
You are doing a really good job, and you will be able to know what is behind your walls. You will be able to know that you have a TT that is better than it came from the factory. Keep at it and then enjoy. Be proud of what you are doing.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
04-24-2016, 07:49 AM
WOW thanks for the pictures, hope a number of folks get it now. Good luck with your repairs it will take awhile i'm sure.
Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
