Originally Posted by Hclarkx
Why get on the roof to clean off the tops of the slide-outs? A telescoping pole with an old terry cloth towel fastened to it works great. Just drag it back and fort from the ground. Dip it in soapy water if you want to wash the SO roofing. Hose off to rinse. As others have pointed out, getting from a rear ladder onto the roof is risky business unless you are young and not very tall. I use mine only as a mount my outside cell antenna.
I get on the roof for several reasons:
1. Wash EPDM every couple months (greatly extends roof life)
2. Service and clean AC units
3. Inspect roof for potential leak areas (Need I say more)
4. Sweep off slide outs because we usually camp in State Campgrounds surrounded by all those lovely trees and the debris will wreck the slide out seals.
As you can see, I have no problem climbing onto the roof. Those of you who are more timid souls should probably keep your feet firmly on the ground
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
