Old 05-29-2014, 08:37 PM   #11
pjones1969's Avatar
Originally Posted by gljurczyk View Post
Did you match a/c's ? Before you install I would recommend you put in a hard start and a time delay so both do not start at the same time. Easier to do on the ground. Turbo had a thread yesterday when the guy's genny had problems on start up. Total cost would only be like $25.00 bucks or so. Then you will have no worries at all. Just a suggestion to you. Good luck on the install. I Wasn't smart enough to get 2 , but mine was bought off the lot with just one not prewired. Never mind I see it done already, but I still would add those to your unit. Your picture posted as I was writing.
I called Dometic and told them what unit I had in the living room, they told me which model number to get, I'll check into the hard start and time delay.
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
bed, roo, vent
