Old 05-23-2014, 07:04 AM   #1
pjones1969's Avatar
Installing 2nd AC in bedroom, existing vent removal?
I will be installing a 13500 in the bedroom on our 2013 Sabre 32bhok this weekend, it is factory prepped and I have located the electrical and thermostat wiring, I just need to know if anyone has any information on the proper way to remove the existing 14x14 vent frame that is currently attached to the roof. I'm not sure how it is actually attached. Thanks
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 05-23-2014, 07:13 AM   #2
AquaMan's Avatar
Remove the inside cover (usually 4 screws) then attack the roof. A heat gun and a plastic putty knife will help remove the caulking around the vent. Once removed and cleaned up, you can remove the screws that hold the vent on. Getting the caulking off is the toughest part of the whole job.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-23-2014, 07:38 AM   #3
TURBS's Avatar
I agree!
TURBS
"Sabre owners united"
Old 05-23-2014, 07:54 AM   #4
pjones1969's Avatar
Thanks guys, I've removed the shroud from the inside and looked around, I was just unsure about how to go about removing the roof mounted piece without messing something up, I guess the new ac gasket will end up being outside the area where the vent was.
B&W Companion
Old 05-23-2014, 08:16 AM   #5
TURBS's Avatar
As Timmy said a heat gun and plastic putty knife works great.
I replaced my vent with a fantastic fan in our bedroom and once I got all the dicor off the screws we're right there.
TURBS
Old 05-23-2014, 08:29 AM   #6
AquaMan's Avatar
My AC install called for putting a bead of Dicor around the gasket, which I did. My roof was cut a bit to the extreme outer edges of my gasket, and I put some extra Dicor around that area. I have a new gasket and I'm going to pull the AC off this weekend, just to make sure all is good, since you really can't see under the AC.
Old 05-23-2014, 09:04 AM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
How are you wiring that 2nd AC?
donanddona is offline   Reply With Quote
Old 05-24-2014, 02:36 PM   #8
pjones1969's Avatar
It was factory prepped already
B&W Companion
Old 05-24-2014, 02:40 PM   #9
pjones1969's Avatar
Done, hardest part was getting the existing vent off, kudos to that factory worker, I hope he is the one that sealed all my roof penetrations.
Only thing that threw me for a loop was the 12VDC From and To connections, finally figured it out, had to tap into the wiring from a nearby light, other than that it went real smooth
Name:	ImageUploadedByForest River Forums1400960364.704544.jpg
Name:	ImageUploadedByForest River Forums1400960403.214516.jpg
Name:	ImageUploadedByForest River Forums1400960418.408184.jpg
B&W Companion
Old 05-24-2014, 02:49 PM   #10
Witch Doctor's Avatar
Did you match a/c's ? Before you install I would recommend you put in a hard start and a time delay so both do not start at the same time. Easier to do on the ground. Turbo had a thread yesterday when the guy's genny had problems on start up. Total cost would only be like $25.00 bucks or so. Then you will have no worries at all. Just a suggestion to you. Good luck on the install. I Wasn't smart enough to get 2 , but mine was bought off the lot with just one not prewired. Never mind I see it done already, but I still would add those to your unit. Your picture posted as I was writing.
Coachmen M/H
Concord
2018 / 300 DSC
bed, roo, vent
