Old 11-09-2017, 09:59 AM   #1
Is this normal ?
We just had a new roof put on and there are bubbles around every opening and along the front and rear of roof. Is this normal ? Shouldn't there be glue in these places to hold the roofing material down. The tech said that it is the solvent in the caulk that causes the puckering of the roof, and that it will lay down when the solvent dissipates. What are your opinions ?
ID:	156077   Click image for larger version
ID:	156078   Click image for larger version
Yeti is offline   Reply With Quote
Old 11-09-2017, 10:08 AM   #2
PPST Wannabe
kenandterry's Avatar
Can you get that in writing?
Of all the posts Iíve ever seen about roofing any RV, Iíve never seen anyone else report this puckering in your photos. What kind of roof material is it?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-09-2017, 10:30 AM   #3
Tech said Alpha Systems. The invoice just says rubber roof.
Old 11-10-2017, 05:21 PM   #4
Iím by no means an expert and Iíve never seen anything like that. Iíve looked at probably 50 campers and havenít seen anything resembling this.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 11-10-2017, 05:37 PM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Weird, please keep posting updates
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 11-10-2017, 05:51 PM   #6
They don't look like that when they come new from the factory. Shouldn't be any different if it is a replacement roof.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 11-10-2017, 06:27 PM   #7
Looks to me like a sealant was used that wasn't 100% compatible with the roofing membrane.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 11-10-2017, 06:32 PM   #8
That's what I'm thinking. Tech said the solvent will dissipate over time. I believe the glue they use on the roof is water based. Maybe the solvent isn't compatible with the roofing material or the glue.
Old 11-10-2017, 06:33 PM   #9
Herk7769's Avatar
Yea, that makes good sense to me.
HAM CALLSIGN - KC3FFW
Old 11-10-2017, 06:59 PM   #10
This is where I am also,well said! Youroo!!
Old 11-10-2017, 07:17 PM   #11
Stank Bait's Avatar
Find out what type material the roof is and contact the manufacturer of the material. Send the pics. That should answer the question. Think your roof installer messed up. That's a poor caulk job on the trim strip too.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 11-10-2017, 07:18 PM   #12
It's Alpha Systems I sent them pictures waiting to hear back.
Old 11-11-2017, 03:49 PM   #13
Evereddie's Avatar
Looks like someone was making a pie.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 11-11-2017, 04:21 PM   #14
Lol 😁
Old 11-11-2017, 04:55 PM   #15
Take it back it is not normal. never saw that on a roof job before, ma be a few wrinkles here and there but that is crazy.
Lappy is offline   Reply With Quote
Old 11-11-2017, 08:49 PM   #16
SailorSam20500's Avatar
When my trailer first came in, there were ripples similar to what you have but no where near as prominent. The ones on my trailer have pretty much flattened out.
Just thinking, it was a week or more between manufacture and delivery of my trailer so there was some time for them to start tightening up before I saw it..
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 11-11-2017, 08:59 PM   #17
Novice Travel Trailer Guy
benchmarks's Avatar
I agree with 5picker #5 above. I worked for a manufacture of epdm and tpo single ply membrane. He is correct in regards that bubbling does occur on membrane due to the off gasing if solvent based adhesives and will suck back down to substrate. HOWEVER, in this case NO! A solvent was used for seaming and it was incompatible with the material. Regardless if this is a thermoplastic or thermoset membrane.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 11-11-2017, 09:55 PM   #18
advice
I wouldn't live with that...the tech is giving you a line of BS.....GO SEE THE SERVICE MGR.....and if he don't put a new roof on for you....keep going to the top....THE SQUEEKY WHEEL GETS THE GREASE......
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
Old 11-11-2017, 11:10 PM   #19
benchmarks's Avatar
But donít use the grease for the seams bahabaha!
Old 11-12-2017, 02:15 AM   #20
spaach's Avatar
I have seen this most notably on epdm roofs. It seems to last about 1 to 2 weeks depending on temperature. It always seems to lay down. Laying a dicor roof with their underlayment glue, putty tape, and sealant from the roof kit will still have this happen.
I have only layed alpha tpo twice also using the proper install kits and had bacon edges for a while as well. It seems to lay down fine but seems very odd for a couple of weeks.
spaach is offline   Reply With Quote
