08-14-2019, 05:55 PM
Is this piece called a "vinyl trim insert"?
I need to replace the 8 foot black screw cover piece across the front of my Mini Lite. It appears to be 5/8" or so wide. Are there other options than Camco to order from online? Thanks in advance.
J and S
2016 Rockwood MiniLite 1809S Sapphire Edition
2013 Ford F-150 SuperCab XLT 4WD 5.0L 3.55 rear Factory anti-sway and brake controller
Equalizer E4 - 600 TW, 6000 GTW
08-14-2019, 09:09 PM
Who Dares, Wins
For some reason "gimp" or "gimmping" or gimp molding popped into my head when I was reading this.
2015 Chevy HD D-Max
2022 Impression 315MB
08-14-2019, 09:32 PM
Local dealer sells it as screw cover on 1/2in or 5/8, brown, black, white.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
08-14-2019, 09:39 PM
I had to replace some of these on our camper this year. Found it on Amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I didnt get the Camco version because I read about it being very stiff and cracked easily when installing.
Camper:
2017 Rockwood Roo 183
~ Sapphire Package, Equalizer WD Hitch, P3 Brake Control
Tow Vehicle:
~ 2008 Toyota Tacoma Off Road
08-15-2019, 05:48 AM
Thank you for the feedback. it looks like you squeeze it to create a hump shape and it fits into the existing channel. Have a great day.
J and S
08-15-2019, 07:23 AM
RV Designer E369 Heavy-Duty Vinyl Insert Trim - Black - 1" x 25'RV Designer E369 Heavy-Duty Vinyl Insert Trim - Black - 1" x 25'
RV Designer E369 Heavy-Duty Vinyl Insert Trim - Black - 1" X 25'
RV upgrades.com
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
08-15-2019, 09:47 AM
measure and get the right width. it comes in various widths.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
08-15-2019, 12:38 PM
^^This is important. Perhaps you could remove a piece of the original to get an accurate width measurement.
Also, it installs better when warm (more pliable). Cut a piece off of the roll (a little long, then trim to exact length later) vs. trying to install it off of the roll.
And don't try to pull it through the track. Get one side to click in the track then work the opposite side into the track. Go back and forth in this fashion.
I installed a bunch of this on our camper.
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
08-15-2019, 04:13 PM
Thanks for the quick replies. It is appreciated.
J and S
08-15-2019, 04:43 PM
Also, Start one side for about a foot or so, work the end of the other edge into its groove, then take a metal spoon and run the edge like you are running the bead on a bicycle tire. Pops that edge in fast and saves a lot of fingertips. A tech in an Alabama campground/sales lot taught me this one.
08-15-2019, 08:14 PM
eBay
Originally Posted by luc
Less costly on eBay. Lots of colors, too. This is the same stuff that's used to cover the rain gutter screws on every trailer.
It shrinks during the first year. Stuff it in tightly to avoid gaps at the ends next year.
Larry
