Old 11-19-2018, 10:33 AM   #1
Issue?
Should this be cause for immediate concern? It is the section between the TPO roof rounding the corner down to the gutter. The silicone is intact, but separating slightly from a complete material to material seal.
The unit was at a dealer 2 months ago for a roof inspection.
2017 Rockwood MiniLite 2506S
2019 GMC Sierra 6.2L
2017 Colorado D-Max pulling 2017 Tracker 175TXW
Days Camped in 2017: 71
Days Camped in 2018: 37
Days Camped in 2019: 15
bshort is offline   Reply With Quote
Old 11-19-2018, 10:44 AM   #2
Coach
One thing you never want to chance is your roof. Doesn't look like a spot that is easily taped so I would cover it with a bead of dicor or geocel. If you have fiberglass sides, any water infiltration in that area can quickly cause delamination.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 11-19-2018, 10:51 AM   #3
I agree... you can never be too careful with the roof.
It's hard to tell from the photo because part of it is out of focus but is the discolored stuff caulking or mold/fungi?
Since it seems to be bled all over that area... is this a spot where water possibly lays?
You'll need to clean that area very well before expecting anything to stick to that.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 11-19-2018, 11:09 AM   #4
It's the vertical side section between the roof and and the metal piece above the gutter. The brown stuff is dirt. The roof actually has sort of a ridge running over the side, so it's not a high water area.
Old 11-19-2018, 11:13 AM   #5
any gaps however small are a problem . clean and re-seal ;
MR.M is offline   Reply With Quote
Old 11-19-2018, 11:17 AM   #6
Only have a tube of proflex handy. Says not to use on the roof.
Old 11-19-2018, 02:40 PM   #7
Depending on roof type... better find some Dicor sealant (made for Dicor's DiFlex type of TPO roof system)... or SuperFlex sealant. (made by Alpha and sold exclusively by Camping World for Alpha's SuperFlex type of TPO roof system)
If you have an EDPM rubber roof system (I don't think so from the photo) find some Geocel Advanced EDPM sealant.
Old 11-19-2018, 04:34 PM   #8
It's a TPO roof. Rain will be here Wednesday and there's no local shop that carries non-sag dicor. I used the proflex.
Old 11-20-2018, 10:42 AM   #9
then don't use it on the roof . go get the correct sealant and get busy
Old 11-20-2018, 12:34 PM   #10
Thanks for that awesome insight.
