Old 04-20-2013, 09:50 AM   #1
Engineer of Crazy Train
ChooChooMan74's Avatar
Just found a leak
We had heavy rain last night. Found a leak coming from the AC unit. Took the plastic off and found it dripping from between the roof and the unit. Is this repairable myself or should I send it out and have my entire roof inspected by my trusted service center?
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-20-2013, 10:02 AM   #2
Just Love to Camp
TheFordes's Avatar
Choo Choo I am not sure but check and post with the Phat Phrog Phamily. Turbs,OC, or one oph those guys can probably help. Turbs might even give a call. He is however going to want pictures.
Sorry to hear. I know that you had a bad enough day yesterday you didn't need this!!!
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 04-20-2013, 10:10 AM   #3
AquaMan's Avatar
You can repair yourself. I've complete installs of A/Cs, and it's not that hard. The leak will be coming in under the foam gasket that sits between the A/C and roof membrane. This gasket can be replaced. Requires removing top unit, removing old gasket, install new, replace. A bead of Dicor between the gasket and roof, will help seal. I remove the top unit by myself, but you may want help.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-20-2013, 11:37 AM   #4
Just Love to Camp
TheFordes's Avatar
See a Phat Phrog to the rescue!!
2012 F450
Virginia
Old 04-20-2013, 11:48 AM   #5
Herk7769's Avatar
That seal will need to be replaced.
Once they get water under them they will not re-seat to the TPO membrane due to dirt that gets under the seal.
The air conditioner is a 2 man lift.
http://www.forestriverforums.com/for...g-on-7112.html
Don't forget to torque ONLY to the tabs touching the roof. Over torquing is just as bad as under torquing.
ID:	28482   Click image for larger version
ID:	28483   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-20-2013, 11:50 AM   #6
DAISY BOYKIN's Avatar
Before you jump the gun!
Try tightening the four bolts down just a little that are in each corner. There should be a yellow tag on each corner inside the air plenum box. These should equal in measurement with the roof line. Usually about one turn on each long bolt will cure the problem, especially if the unit is fairly new. The bolts simply pull the AC unit down on the roof compressing the gasket stopping the leak.
Good luck
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 04-20-2013, 11:59 AM   #7
67redbowtie's Avatar
I had the same problem a couple of years ago. Remove filter cover and notice my bolts were lose. Torqued bolts back down. Leak went away.
67redbowtie is offline   Reply With Quote
Old 04-20-2013, 02:47 PM   #8
Thx guys. I will check tightness first. See if that helps. If not, then I will get a new gasket.
Poor signals a the campground this weekend.
Locomotive Engineer
Old 04-20-2013, 03:13 PM   #9
Ok, pulled out my package of manuals. Read the AC installation manual. Saw to tighten to indicators are at roof level. They "looked" ok. So I tightened the rears a quarter turn or so. Went to the fronts where it was leaking from and they were way looser. So I tightened them until the same feeling. I used a screwdriver without the bit... Same size hex. I didn't wrench it tight. Just to the same torque feeling. Either it will not leak or still leak. 50/50 shot.
Locomotive Engineer
Old 04-20-2013, 03:44 PM   #10
VinceU's Avatar
Gotta garden hose near by? Shoot the joint with medium pressure/nozzle setting, you'll note real quick if it worked!
Old 05-13-2013, 05:14 PM   #11
Torquing the bolts down appear to solve the problem. All looks fine now after a few heavy rainstorms and hosing tree droppings off the roof.
Locomotive Engineer
