Old 03-06-2017, 08:56 AM   #1
Keep the Rubber Boot on Antenna Cable
We have had the same problem with several TT's & 5th wheels. The TV antenna coax cable has a rubber boot on it (on the roof) which slides over a metal collar where it goes through the trailer's roof.
They always ride up, off the metal post (like the picture shows). In the past, in extreme rain storms some rain gets in through this. How do I make the rubber boot stay on the metal post?
Hate to try glue... it would be a mess if antenna/cable ever had to be replaced.
Any suggestions?
PapaE is offline   Reply With Quote
Old 03-06-2017, 09:33 AM   #2
Perhaps a tie-wrap (cable tie, zip tie, or whatever you call it wherever you are) wrapped around the cable just above the boot?
matwiyj is offline   Reply With Quote
Old 03-06-2017, 09:45 AM   #3
Sounds like a good idea. Just don't cinch the zip tie on the boot itself. And you will have to inspect it periodically as the sun will cause the zip tie to deteriorate over time.
Old 03-06-2017, 09:48 AM   #4
WFD
That would probably be enough to keep the boot from sliding up...good idea.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-06-2017, 09:48 AM   #5
(Dry Huunday)
DreiHunde's Avatar
I Zip Tied the boot several years ago when I noticed it had moved, never an issue since.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 03-06-2017, 09:52 AM   #6
Flybob's Avatar
You can also use something like "Shoe Goo" which is similar to thick rubber cement. It will hold the boot on and is fairly easy to remove if you ever need to.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-06-2017, 09:54 AM   #7
Lacey's Spring, AL
formerFR's Avatar
or just a quick dab of regular silicone
formerFR is offline   Reply With Quote
Old 03-06-2017, 12:10 PM   #8
Thanks to all for the ideas. I quoted this one because I am going to try the cable tie on the coax just above the boot. Actually, when I read it... I said to myself... why didn't I think of that. Especially, since I use those cable ties for many things already.
Old 03-06-2017, 02:11 PM   #9
Dale
i have used silicone and lasts for years.
djreg is offline   Reply With Quote
Old 03-07-2017, 01:56 PM   #10
waiter21's Avatar
I fill the boot with clear silicon sealant, then slide it over the protrusion. Guaranteed to seal against water, and will not slide off.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 03-07-2017, 06:25 PM   #11
tomfmcs's Avatar
go to amazon and get some coax seal. tar like stuff that stays in place. use it on all my antenna coax connections. also comes off easy when you need it to.
https://smile.amazon.com/Universal-E...ords=coax-seal
tomfmcs is offline   Reply With Quote
Old 03-07-2017, 06:56 PM   #12
BendOrLarry's Avatar
A dab of Dicor around the top opening and the base of the boot, good to go.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 03-07-2017, 07:15 PM   #13
B and B's Avatar
X 2
antenna, cable
