You need to post more information here so that someone may be able to help you. A picture of your problem would be great.
It sounds like you are talking about the front landing legs of a fifth wheel type unit. If so they may be the stile that has a pin through the landing leg. If so you must hook up the unit to your truck, raise the landing leg, then pull each pin one at a time and push up on the bottom portion of the leg, it will slide into the upper portion, then reinstall the pin in the closest hole to hold the leg up.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
