Old 08-18-2015, 10:40 PM   #11
rsdata's Avatar
rvroofer...
you mentioned twice this product... care to share what it is?
use a 4" fiber backed seam tape that accepts a coating and coat, never have to inspect your seams again.
thx for the info...
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-26-2015, 08:59 AM   #12
raytwntrvlr's Avatar
Originally Posted by rsdata View Post
rvroofer...
thx for the info...
Yes, RVROOFER, Inquiring minds want to know.... what is this miracle product you allude to?
I'm guessing it is some thing you have a connection with, as in, you have developed it and are marketing it perhaps?
Anyway, please enlighten us.
2015 Flagstaff Super V 26VFKSS Emerald
raytwntrvlr is offline   Reply With Quote
Old 08-26-2015, 09:27 AM   #13
rsdata's Avatar
Did a google search and came up with what I believe is HIS Facebook page...
I suspect that his fiber-backed tape is part of his roofing system that he uses for roof repairs... maybe he has it custom made? or uses some off-the-shelf product then covers it with another product.
https://www.facebook.com/NeverLeakRVRoofing
more power to him if it works...
2014 Shamrock 183
Old 08-26-2015, 09:29 AM   #14
f5moab's Avatar
I carry a tube now, as well as a small roll of eternabond, after having a large pine tree branch arrow down into the roof. All I could find locally at the time in the middle of the Wind River range was silicone. It worked at the time. (Pain having to lower the roof fix and raise again.)
When I returned home, I removed it and applied Dicor, and the a 4x4 inch eternabond patch.
f5moab is offline   Reply With Quote
Old 08-26-2015, 10:25 AM   #15
Never Leak RV Roofing
Yes, it is manufactured in Canada along with the coating and the primer, the combo of all three is how we are able to get the warranties we do, all i know if the lap sealant, self leveling caulking caused the roof leak why put it back on, and keep climbing on your rv roof multiple times a year to inspect it.
rvroofer is offline   Reply With Quote
Old 09-23-2015, 03:24 PM   #16
Pickin' & Campin'
And yet we still don't know what it is called or where to purchase.
rvroofer, are the three items you spoke of (4" fiber tape, coating and primer) available from you or your company? (or anyone else for that matter?)
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 09-23-2015, 05:40 PM   #17
www.fibertapecoatingandprimer.com
i kid, i kid.
Riccochet is offline   Reply With Quote
Old 09-23-2015, 05:59 PM   #18
WestCoastRV'er's Avatar
This spring I'm going to be cleaning up all the dicor I've applied and use 4" or 6" Ethernabond to have a permanent solution.
Dicor (self-leveling & non-leveling) and Ethernabond should be in every RV'ers toolbox.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 09-24-2015, 07:29 AM   #19
MtnGuy's Avatar
Originally Posted by Rich70 View Post
I found the marker lights to be a source of leaking problems. T
The inside of my front closet was getting wet. After multiple trips up on the roof with the caulk gun, I finally checked out the marker light. I tiny little crack in the caulk was causing the problem.
Another place to check and caulk is the area between the bottom back of the fridge and trailer side.
Old 09-24-2015, 12:37 PM   #20
yes Brentwood coatings...
delamination, forest river, lap seal, quality, factory, leak
