Old 07-01-2015, 10:32 AM   #1
Leak from antenna handle
On my last trip we had quite a bit of rain. I noticed a leak from the handle of my antenna. I have researched this problem and spoken with my parts dealer about it, and he told me 90% of the time the boot that goes around the cable pops loose and you just have to pop it back in place. Yesterday my son went up on the roof - and we do not have a boot! Also, the antenna seems like it needs to be tightened down, but we can see no way to do that. Can anyone give me pointers on what to do? It is a 2012 Rockwood Mini Lite 1905.
roxie1824 is offline   Reply With Quote
Old 07-01-2015, 10:40 AM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Dicor Lap Sealer
Robot Check
Name:	Dicor Lap sealer.jpg
donanddona is offline   Reply With Quote
Old 07-01-2015, 10:59 AM   #3
Left Coast
I think there's an 'o' ring that seal on the shaft...been awhile since i've looked...they come apart easy, handle first, then from outside.
Old 07-01-2015, 11:08 AM   #4
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 07-01-2015, 04:08 PM   #5
rsdata's Avatar
THANKS cpd1343
EXCELLENT video link!
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 07-01-2015, 06:35 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I had the same problem several years ago on a different RV and water got un under the roof membrane and cause a lot of wood rot to the point where the roof was soft all over that area. You better get it fixed before your roof gets into more jeopardy. It's coming in somewhere at the base up on the roof. How to fix it, I don't know,,,,but it's going to create some serious problems for the structure of your roof soon.
Check with an RV dealer service department.
Grampa Jim is offline   Reply With Quote
Old 07-02-2015, 07:12 AM   #7
water dripping from antenna handle
We had same problem this winter we found that the rotating handle loosens up from its shaft we loosen the set screw in the handle and push it up .You might need needle nose pliers to hold shaft from pushing up
kendochenetz is offline   Reply With Quote
Old 07-02-2015, 08:05 AM   #8
As been posted there is a Quad (yes 4 sided) O ring on the shaft that the crank attaches too. When it wears out you will get leaks like you mention. I just replaced the shaft this winter - looked on U Tube on how to replace the shaft & found it was very easy job. I am assuming you have the Wineguard antenna - the repair shaft Model RP 4000 cost me $13.06.
PM me & I can walk you thru the process after you watch the U-Tube video.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
antenna, leak
