It is a Flagstaff 28' Classic Lite 5th wheel. I haven't really memorized the model number you. When I get home from work, I'll take a look. I just discovered a water leak in the bottom compartment on the right side of the fireplace. Inside that compartment, behind a faux wall-board, are the TV/CABLE and POWER inlet ports. The floor was soaked with water and the outboard wall seemed especially damp just under the power inlet port. On the outside of the RV, the port and seal looks good. I cannot determine where exactly the leak originates. It must be coming from one of the ports. Anyone have an idea why new ports should be leaking? I plan to put clear silicone around the ports because it is a real pain in the ***** to take it back to the dealer (I'm a full timer). Any ideas or suggestions will be appreciated.
