Old 11-01-2012, 01:35 PM   #1
Leak under refridgerator
We have a 2009 Cardinal 3100RK. Our refrigerator is located in the rear corner of the slide out. There are 2 vents for air circulation on the outside of the side. Recently we have had many days of constant rain. While searching in the storage area under the fridge, I noticed the carpet was soaked. The refrigerator is running fine. No obvious leaks on the roof. Has anyone any suggestions? Thanks.
javahh0 is offline   Reply With Quote
Old 11-01-2012, 01:57 PM   #2
Dave_Monica's Avatar
Welcome to the forum!
Have you checked the drainage hose from the fridge for cracks/holes? Is it still attached to the outside cover?
Dave
Old 11-01-2012, 03:17 PM   #3
No I have not, Dave but I will check the hose. Great suggestion!
Thanks.
Old 11-01-2012, 03:29 PM   #4
Herk7769's Avatar
My hose was up and inside the compartment.
I had to fish around inside to find it when I first took the camper home.
It needs to be routed through one of the lower vent slots so the drainage leaves the camper.
HAM CALLSIGN - KC3FFW
Old 11-06-2012, 06:48 PM   #5
Many thanks to you! You nailed the problem. Not only was our hose loose but it was brittle from the extreme heat of 3 years in Las Vegas. I guess a sun shade doesn't prevent alll damage!
cardinal, kitchen, leak, refrigerator
