Old 05-13-2013, 10:06 PM   #1
leaky sunroof over dining room table - sandpiper 2007 - 315 bhs
found leak on the sunroof, was dripping on table..
climbed and started to pull awa y the easy stuff
see pics
here is the plan
1. clean down to plastic sun roof about 1" from edge toward the center
of the center, go around the sun roof
2. clean down to the original roof about 2" away from the sun roof ..
3. fill in with ????
4. seal with ??
what do I use ?
ID:	30440   Click image for larger version
ID:	30441   Click image for larger version
ID:	30442   Click image for larger version
subzeroschmidt is offline   Reply With Quote
Old 05-14-2013, 06:46 AM   #2
update
plan is to :
1. remove sky light
2. clean everything
3. put double sided Eternabond under sky light
4. put about 4" wide Eternabond on top over the edge ...
just to clean the old stuff away
and find some Eternabond
Old 05-14-2013, 06:54 AM   #3
Originally Posted by subzeroschmidt View Post
plan is to :
1. remove sky light
2. clean everything
Make sure you clean all the surfaces you want to tape with acetone.
