Old 06-19-2016, 09:00 AM   #1
Little dab of silicone or putty tape the whole thing
So I was treating the front cap of our 2016 2906 WS and needed to get on the roof to do the very top of it. While up there, I noticed that the putty tape they put over the joint seems to have a void. Also, you can see where the edges of the channel are poking through on both sides.
First picture showing the void and the black edge of the metal seam poking through the length of the joint:
Closeup of the void:
Maybe this is just cosmetic and all the actual sealing is beneath?
Would you just clean and fill in that void with caulk or would you clean everything and get 10 feet of putty tape and put over the length of it?
Thx. Newbie here so please be kind.
ID:	111560   Click image for larger version
JeffandLori is offline   Reply With Quote
Old 06-19-2016, 09:31 AM   #2
Your pictures aren't showing up.
On my 5er we had the same problem as you described. I just permanently fixed it with a wide Eternabond tape strip.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 06-19-2016, 10:18 AM   #3
Thanks. Added them as attachments. We'll see if that works.
Old 06-19-2016, 10:25 AM   #4
SeaDog's Avatar
You can clean seam with alcohol and then go over it with self leveling chalk or you could use eternabond tape as mentioned it does come in many widths
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-19-2016, 12:33 PM   #5
Rockin M's Avatar
I also used the Etnabond Bond tape on my Class C Forester. I does a good job but its difficult to wrap it around the down turning corners and keep it neat. I ended up piecing it around the corners. It looks just OK.
Also I am wondering how some of that material that is used to completely wrap vehicles would work to seal around the joints between roof and cap and other areas of concern. I believe it is applied using its peal and stick coating then the installer uses a heat gun to draw it tighter to the joint. I bet an RVer could buy enough scrap or unused pieces from a wrap vendor and give it a try. Surely there is a YouTube video with installations instructions. I'm going to give it a try.
Barry & Donna
2014 Forester 3011DS
2013 Chevy Equinox
Rockin M is offline   Reply With Quote
Old 06-19-2016, 12:39 PM   #6
camaraderie's Avatar
Whatever you do...NO SILICONE...or when that fails (and it will) nothing else will stick for the fix. Follow the advice of others based on your roof materials.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-19-2016, 12:44 PM   #7
Silicone won't stick to a rubber roof. I never use it on anything on my RV. Use a good self leveling caulk. If you want you can put Eternabond over the top of that. Whatever you decide. fix it soon!
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 06-19-2016, 01:33 PM   #8
grumpy0374's Avatar
Can't tell if that's a fiberglass one piece roof from the pic. But, for the life of me, it almost looks like the front cap is pulling away from the roof.
How old is your rig, and is it under warranty? If it is I would get it to the dealer ASAP, as you have some big gaps there.
If not under warranty, get yourself a couple of tubes of Dicor Self Leveling Caulk. Clean the old caulk and area in fromt and behind the caulk with mineral spirits, and then go over it with acetone till its dry, residue free, and squeakey clean.
Run a generous bead of Dicor over the old caulk, and squeeze it down into the gaps. Don't be stingy with it...spending 20-30 bucks for 2-3 tubes of Dicor is cheap compared to water damage repair.
If it were mine, I would then, over the caulk (once it's set up) use a 4" wide strip of Eternabond to overlap the entire seam.
Sounds like a lot of work...it's not...an hour or so. But you will end up with a water tight seam.
I never had a problem with gaps such as yours. But when new, I did exactly as I mentioned to the front and rear seams where caps meet roof. That was 3 years ago, and caulk and
eternabond is still as good as the day I put it on.
Grumpy
Steve & Cheryl + Charlie & Zoey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-19-2016, 03:38 PM   #9
I had this problem on a Rockwood. Turns out the cap warped from insufficient bracing (known problem), letting air get under the vinyl roof like a balloon. Hope it's under warranty
Tim & Eileen
2016 Cedar Creek 34RL towed with a 2017 Silverado 3500HD Diesel
timerie is offline   Reply With Quote
Old 06-19-2016, 07:39 PM   #10
Thanks all. Unit was bought brand new in October. So, I'll be calling the dealer tomorrow. To me, it just looks like the caulk has flowed down around whatever metal strip they use to join the two. But I don't know anything.
Thanks an will update you all.
