Old 07-08-2019, 06:26 PM   #1
fenton04's Avatar
looking for guidance
I do not have home or storage lot access to water to wash my travel trailer. (coachmen apex 249 RBS). Trying to think outside the box but so far coming up empty. What other solutions are out there to wash my travel trailer. Thanks in advance. OBTW I have geared up to wash it myself.
Tow vehicle 2015 Nissan Titan PRO 4X
Coachman 2019 Apex 249 RBS.
Where to next?
Tony, and Vicky
fenton04 is offline   Reply With Quote
Old 07-08-2019, 06:28 PM   #2
Flybob's Avatar
How about a friend who has some room and a hose. Also one of the do it yourself washes if near you. Just be careful if it is a pressure washer type wash.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-09-2019, 09:15 AM   #3
I have had that problem, and just used the waterless spray cleaner. It works reasonably well, although it will not get all the baked on water spots off. After using it, I wax it, which takes off what the waterless wouldn't do. It's a workout, but solved my problem.
Wileykid is online now   Reply With Quote
Old 07-09-2019, 09:21 AM   #4
This works well !
https://www.amazon.com/Aero-Cosmetic...s%2C138&sr=8-3
2018 freedom express 248 rbs
2017 Silverado 1500 double cab max tow
dennis110r is offline   Reply With Quote
Old 07-09-2019, 09:36 AM   #5
If you are able to wash it without restrictions (like at the storage lot) just put water in your fresh tank and put a couple fittings/valves on your low point drain lines and attach a garden hose to it. Turn on the pump and... Wala!
Here are my low point drain valves that accept a garden hose.
Open and turn on the pump and you have your own water source.
Purchased from McMaster-Carr, SMC brand.
I've even done this at campgrounds that don't allow washing. I asked if it would be OK if I used my own water from my tank and they said yes. What they didn't know was a few hours prior, I had used their water to add to my tank! Sshhh....
Days Camped: '16=46 '17=30 '18=51 '19=27
