Old 11-30-2009, 09:01 PM   #1
meredog's Avatar
loose siding
just picked up toy hauler from rv service center today. when i got home i noticed a peice of the aluinum siding had seperated where two peices joined. i was able to slide the piece back into place but am sure as soon as start driving it again it will seperateagain how di fix
2001 FOREST RIVER AMERICAN SPORT TOY HAULER
2006 DODGE 3/4 TON W/CUMMINS DIESEL
2005 SUSUKI BLVD W/LEMANTRIKE CONVERTION
meredog is offline   Reply With Quote
Old 11-30-2009, 09:10 PM   #2
Knower of Some Things
There is a way to cheat, if you don't care much about details. Take a medium size pneumatic staple gun or screw, and screw/staple the lower piece (as close to the joint as possible) through the S lock of the top piece into the stud behind it. Otherwise, you will have to take off a bunch of metal below it to access the S lock by itself. The trailers are sided at the factory from the top down. To fix it, work from the top up.
If it is a lower piece of metal, sometimes the staples going through the bottom up into the floor come out, and that piece of metal sags down a bit. In that case, just staple it at the bottom.
Can you post a picture of the seperation up close, and from a distance so the surroundings can be seen?
PumaPro is offline   Reply With Quote
Old 12-01-2009, 02:26 PM   #3
meredog's Avatar
I posted spme photos here
http://s222.photobucket.com/albums/d...orest%20River/
Herb
