04-15-2017, 07:39 PM
Many, Many lose screws.
On the road on the way home stopped at a campground for a few days. While doing a little visual outside inspection noticed some screws backing out of slides and other places. Grabbed my screw driver to tighten them up. Most of them acted as though they were stripped out. So sad. I have a thought on how to attack this problem but would like some input on what you guys would do.
Twisting the night away.
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
04-15-2017, 07:47 PM
1. get a jar to put loose screws and things in that you find on the floor.
2. get a tube of Loctite.
3. have fun putting them back in.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
04-15-2017, 07:58 PM
Tooth pics dipped in wood glue,put 2-3 in hole and break off even! Run screw in by "HAND" till tight! Done Deal! Youroo!!
if they are stripped, I would replace with the next size screw, ... and if outside, I'd certainly use stainless, ......
04-16-2017, 11:16 AM
That was my train of thought youroo. Thanks for the info guys.
2012 Sabre 34REQS6
04-16-2017, 11:22 AM
Yup!
Or one could fill the hole with JB Weld let it cure and then drill a starter hole then put the screw back.
04-16-2017, 12:02 PM
Get a piece of 1/8" or 3/16" /etc dowelling and dip into glue and gently hammer it in hole...Works!!!!!!!!!
04-16-2017, 12:07 PM
Take a small tie wrap or two, put a bend in the end = the hole depth. Use 1 or 2 in the hole as needed. Insert screw and secure. Cut off excess tie wrap
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
04-16-2017, 12:13 PM
Works really well. Done it many times, even on the boat which takes a pounding, and has always held up.
04-16-2017, 12:21 PM
Thin and short length of solid copper wire placed in hole then put screw in same purpose of toothpicks. Copper is soft and will take the threads of the screw
04-21-2017, 03:54 PM
Are screws outside on slide? My slide had too small of screws and not enough. I'll try to add photos. Couldn't find any.
04-21-2017, 04:22 PM
Mddle of the Rd Extremist
On the advice of a guy who'd been RV'ing for at least a hunnert and fitty years, I go around our entire rig every six months or so and check every visible screw for tightness. First time I was amazed, now, not so much....just part of owning a house that rolls down the highway and takes me to happy places all over our great country
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
04-26-2017, 01:43 PM
The toothpick method is the correct way.
04-26-2017, 01:46 PM
Yeah, everything needs to be tightened often.
I was utterly shocked to find that all the nuts holding the floor to the frame of my unit were loose. I only discovered it while investigating another construction issue. Every last one....some were almost all spun off. I changed them to nylon lock nut after that.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
04-26-2017, 02:24 PM
Hmmm DW says I have loose screws??? I never understood.
2017 Puma 297RLSS
04-27-2017, 10:37 AM
great info on holding in loose screws! toothpicks, matchsticks, dowels, copper wire, zip ties, jb weld, next size up screws, nylok, Loctite, etc. I guess i'm not the only one that has had screws fall out.
05-06-2017, 08:34 AM
Handyman
Drive in a glue coated, wooden golf tee.
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
